Questionable original motor?
Old May 13, 2003 | 08:11 AM
JDM1975's Avatar
JDM1975
Question Questionable original motor?
Iam in the process of tracing wires in this truck (1975,see gallery) 360? The distributor has points and not electronic.
By the Haynes manual I have, electronic was after late 1974. It has a voltage regulator and no module like what is pictured.
How do I tell what motor is in this truck? (yr/302,360,460,etc.)
Iam still looking for pics of 1975 wiring under the hood? Some wires need replacing due to heat damage and age. Any help appreciated.
Thanks
John
Old May 13, 2003 | 08:14 AM
SDElwood's Avatar
SDElwood
Beer Fridge Finder
All you need to do is get the casting number off the block and it will tell you everything you need to know.
Old May 13, 2003 | 09:49 AM
JDM1975's Avatar
JDM1975
Where do I find the casting number?
The number on the intake manifold is D5TE9425KB?
Number on drivers side head- At first plug (203) second plug-D2TEAA?
Help
Old May 13, 2003 | 10:51 AM
laptopgeek's Avatar
laptopgeek
Pretty truck! It be slammin'! If you're ever headed up towards Rome, drop me a line; I'll introduce you to Harrison ------
Old May 13, 2003 | 11:10 AM
SDElwood's Avatar
SDElwood
Beer Fridge Finder
Well, the D5 on the intake means it is a 1975 intake manifold.
C=1960's
D=1970's
E=1980's
etc..
The following number is the year.
So you know that D5=1975
The casting number should be right above the starter.
Old May 13, 2003 | 12:56 PM
Mil1ion's Avatar
Mil1ion
Those are design cast numbers.
Look more for number like this * 1K20 *
Also, you're taking the long route.
How mnay valve cover bolts on each one?
Do the sparkplugs all face the same way per side or do the 2 rear plugs face the front 2?
Old May 13, 2003 | 02:17 PM
JDM1975's Avatar
JDM1975
Each cover has 5 bolts.
The back two plugs face foward.
John
Old May 13, 2003 | 02:23 PM
Chas1234's Avatar
Chas1234
I have the *D4TE* block in my 1975 -the casting number on mine is upside down above the oil filter adaptor !
Casting numbers on FE's can't tell you much , only the year it was cast-lots of FE's used the same casting number for different engines.
I have pictures but they are too big to put on this site sorry --
That is a FE by the way -it looks like the dura-spark coil too I bet someone just put the points in because they couldnt get the dura spark to work correctly.
Old May 13, 2003 | 02:28 PM
JDM1975's Avatar
JDM1975
Would you email them?
Thanks for the info I will look now.
JD
Old May 13, 2003 | 02:51 PM
Chas1234's Avatar
Chas1234
I looked though my pictures and I do not have a photo of the casting numbers --just a frontal look of the engine-all the rest are my old man's 400 .
Old May 13, 2003 | 04:36 PM
Mil1ion's Avatar
Mil1ion
1975 360?
John
It's an FE block...I would say yes, a 360.
Old May 13, 2003 | 06:23 PM
JDM1975's Avatar
JDM1975
Chas are you saying the coil is correct but the distributor is not?
I would assume that the points dist would fit both. If thats the case I need to find the details for setting the points etc. I really dont want to mess with it too much, besides an oil leak the thing runs great.
JD
Old May 13, 2003 | 06:31 PM
Mil1ion's Avatar
Mil1ion
I suggest having a look here at these two places!
http://www.bob2000.com/dist.htm
http://www.tispecialty.com/articles/article4.htm
Old May 13, 2003 | 06:59 PM
Chas1234's Avatar
Chas1234
What I am saying is that the picture of the coil in your gallery has the dura-spark horseshoe connector on it . If you truck is a 1975 it would have duraspark on it from the factory!
If the points run well on it then keep them ! _ I run them on my '74's 240 and I dont have any problems with them -lots of power and it idles fine!
I say dont bother spending the money for unnecessary parts if the truck runs great!
If you are looking to do a restoration of the truck then you are going to get all the dura-spark stuff to make it work!
Try doing a search for "dura-spark conversion" - and see what you come up with here on this site!
Good luck!
Old May 15, 2003 | 11:54 AM
JDM1975's Avatar
JDM1975
Thanks for the help!
Bennisriley
Dec 15, 2016 07:03 PM
Colorado Highboy
May 3, 2016 03:23 AM
824x4ride
24
Mar 26, 2004 05:52 PM
1975 f150 360
Oct 17, 2003 12:35 PM
JDM1975
Jun 2, 2003 05:18 PM
