The bolt pattern may work but I do not see any mention as to the off-set for these wheels. A wheel with a 10” width may have a backspace ranging from 3 – 6 inches on average and some may be less or more depending upon the application. Can the owner measure the back space for you and then you can have a better idea of how far in or how far out your tires will ride in the wheel well. The shorter the back space, the closer the tire will be to the truck. Are you running stock tires?
Edit: I see in the other pic the off-set is almost 5 inches so that answers that question. Now it all depends on what tire you are using
the second picture says 25mm offset, then im guessing that 4.9 on the same tag maybe backspacing. Im running stock wheels with 315x75x16. These wil be to put my next set of 35's on when I need them. Just liked the look and they look like a good deal to me.
