Towing question
Old Aug 15, 2012 | 06:52 AM
tmcalavy's Avatar
tmcalavy
Towing question
Got a question and can't find the answer in other forums so I'd though I'd ask the experts here. Need to tow my 2wd 93 Ranger pickup behind a big moving truck from Texas to Mississippi. I'm thinking tow dolly, drop the driveshaft and go...carefully. Do I need to cap off the rear of the tranny after I pull the driveshaft...will it puke tranny fluid without the driveshaft installed. Thanks in advance.
Old Aug 15, 2012 | 03:07 PM
Freightrain's Avatar
Freightrain
Best bet is to leave shaft IN the truck. Disconnect at rear end and strap it up to the frame/crossmember. That way no fluid can be lost AND don't have to worry about where to store it.
Make sure you strap it up good!!! Don't want to loose it on the road either LOL!
Old Aug 16, 2012 | 05:58 AM
Gouge Eye's Avatar
Gouge Eye
Moved a 74 El Crapino from Arlington, TX to Destin, Fl on a rent-a-dolly.... we backed that puppy up on the dolly, locked the steering, AND tied the wheel off with rope for a backup.... (tow truck trick)
Your FLAPS should have a plastic cap just for what your doin, if they look at ya like your crazy, run across the the street to the tranny shop, he'll have one... but really now, pull the DS (tape up the outputshaft, dirt, grime, ect), and drain the tranny.... you need to change the fluid in it anyways, right?
Old Aug 16, 2012 | 05:01 PM
Alex from GA's Avatar
Alex from GA
I don't understand the reason to disconnect the driveshaft if the rearend is going on the dolly. Just hook some magnetic lights to the hood, lock the steering and tow it.
Old Aug 16, 2012 | 05:53 PM
jowilker's Avatar
jowilker
TM, Like da train, I disconnect the ds at the rear, pull it over to the side and tie it off with a forward pull to keep it in the tranny. When you arrive you should be able to reconnect and go with no issues.
John
Old Aug 17, 2012 | 12:09 AM
Big_Foot's Avatar
Big_Foot
The front will be on the dolly; ie the correct and safe way to use a tow dolly.
Another vote for disconecting the drive line from the rearend and strapping it up, done this a few times. Works like a charm.
Old Aug 17, 2012 | 03:01 AM
willowbilly3's Avatar
willowbilly3
Don't forget to tape around the U-joint so you don't lose the caps.
Old Aug 17, 2012 | 02:46 PM
tmcalavy's Avatar
tmcalavy
Thanks guys...found a 12-point, 12mm socket that I'll get tomorrow...the little Rangers require it on the driveshaft nuts. I'll put the nose on the dolly, pull the DS and baling wire it up to the frame after I wrap and tape the tail...probably some rope, too. Gotta haul it 3 days chasing a new job opportunity...what's the old saying...a move and a fire accomplish about the same thing for thinnin' out your stuff.
gogreenwave
Nov 26, 2015 11:01 AM
rel3rd
All Things Towing
18
Aug 1, 2011 07:09 PM
nikko3993
All Things Towing
Aug 10, 2007 02:02 PM
hedgeapple
Feb 4, 2006 07:06 AM
spikedog
General Automotive Discussion
Sep 6, 2005 11:56 AM
