Fan clutch
Old Aug 14, 2012 | 07:10 PM
jleal_21's Avatar
jleal_21
Fan clutch
Ive started to suspect that my fan clutch is starting to go bad if it is not already bad. My truck does not overheat yet, but when I take off it roars a lot and my temps have been a bit higher than when I first got it. Like I said it doesn't over heat I just hate that loud roar. Any tips on diagnosing it?
Old Aug 14, 2012 | 07:21 PM
ReBilld's Avatar
ReBilld
Usually the roar means they're working, unless it doesn't stop roaring when you get up to speed. I'm pretty sure mine's bad, it doesn't roar and with the engine off, I can spin it pretty easy with little resistance.
Old Aug 14, 2012 | 07:41 PM
mjonesjr's Avatar
mjonesjr
I believe the fan clutch is designed to fail locked.
Old Aug 14, 2012 | 10:07 PM
oldbird1965's Avatar
oldbird1965
That's interesting mj!
Old Aug 14, 2012 | 10:16 PM
jleal_21's Avatar
jleal_21
So if it fails locked it will always roar? I also noticed that when I shut it off it spins a little while before it stops. Not much just a few seconds.
Old Aug 14, 2012 | 11:32 PM
Talyn's Avatar
Talyn
Correct sir.
Old Aug 14, 2012 | 11:33 PM
Talyn's Avatar
Talyn
Yes, it will be noisy as hell when it fails.
While cold, as in sitting over night.
Open the hood and give it a wing, how well does it spin?
Mine never really "freely" spun (like a box fan, there should be resistance) on my truck, but it was never too stiff.
Check for end play in it by trying to flex the fan back and forth also.
Its hot out, so if it's warm in the engine bay, then the fan will start working.
Just for fun check over your coolant and such to make sure its all hunky dory.
Old Aug 15, 2012 | 06:40 AM
DIYMechanic's Avatar
DIYMechanic
It sounds to me like your fan clutch is working just fine and you're actually getting a lottle on the warm side. Check the coolant levels, make sure the radiator isn't all clogged up with something that got through the grill (visually). I would suspect a thermostat issue, but I am not sure that the fan clutch would engage if the thermostat was sticking because I don't know if the radiator would get warm or not.
maxtruck00
Jun 17, 2014 08:51 PM
lght1
Apr 21, 2013 09:09 AM
Jayme Duty
Sep 7, 2011 11:32 AM
aerostarman2002
Aerostar
Dec 21, 2003 07:31 AM
stryder
Nov 24, 2001 09:58 AM
