Chip is in!!
Old Aug 21, 2012 | 07:59 AM
  #76
Action4478's Avatar
Action4478
Originally Posted by oldbird1965
The guy was a genius!
Rick, I don't know if you read my post 'TC lock' but mine is not locking until it gets into 4th gear. Do you think my 'Cure' failed me or maybe the wire plug is messed up? Its been a long time since I installed it. Thanks
The Cure is supposed to speed up the lock (remove heat ) , it's possible you may have a loose connection ..
My program is 123 TC, 4 (TDE 1) under normal acceleration..
I can Check with Racer if you like .Can you link me to the thread ?...
BTW , I also have the cold shift schedule, I use the OD off button when the Trans Fl temp is below 60 degrees
Old Aug 21, 2012 | 05:37 PM
  #77
oldbird1965's Avatar
oldbird1965
https://www.ford-trucks.com/forums/1182062-tc-lock.html
I also use the OT button off until it warms up a little. To me it almost seems like its on a timer instead of trans temp, IDK. Mine is also 1,2,3, TC & 4, until a thousand miles ago. I don't recall my PCM code. Don't go out of your way to ask Racer X but if you do I think they have my PCM code from when I ordered the valve body. Thanks again!
Old Aug 21, 2012 | 06:16 PM
  #78
Action4478's Avatar
Action4478
If beans is your tuner they can remove the "no TC lock till warm
timer, (up to 600 seconds )
I talk to racer often ' I'll link him to your thread ...
Old Aug 21, 2012 | 11:30 PM
  #79
oldbird1965
Ya Rick, I am running Beans tunes now. I'm so much in the habit of using the OD button it really doesn't matter. But if I send it in for a reburn I'll mention it.
Old Aug 23, 2012 | 07:46 AM
  #80
tshrager's Avatar
tshrager
Thanks for the high jack Glenn!
Ok back on topic, finally got to pull about 7k last night and this chip continues to impress. As most of you know, these trucks stock don't like pulling heavy till you're up in the rpm's. With the chip, it just flat out goes. Absolutely loving the purchase!
Old Aug 23, 2012 | 09:08 AM
  #81
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Talking
Old Aug 24, 2012 | 10:30 PM
  #82
oldbird1965
Glad to help out Todd, just remember, Jose made me do the highjack!!
Old Aug 27, 2012 | 09:15 AM
  #83
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Question
: Me??, I havent talk (written) any word in this thread, till now
Old Aug 27, 2012 | 10:00 AM
  #84
oldbird1965
I had to blame someone, I'm always innocent!!
Old Aug 27, 2012 | 01:00 PM
  #85
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Talking
Even more, I DONT know him
Old Aug 28, 2012 | 07:12 PM
  #86
tshrager's Avatar
tshrager
Well I knew it would happen sooner or later, but I didn't think it would happen this fast. I'm already bored with the chip. Stage 1's...........
Old Aug 28, 2012 | 07:16 PM
  #87
ReBilld's Avatar
ReBilld
Already?!?!?!.........have you gotten out of the truck since you got the chip?LOL!!!
Old Aug 28, 2012 | 07:25 PM
  #88
tshrager's Avatar
tshrager
Nahh, not too much. Towing is immensely improved, but day to day I'm already bored. Oh how my wallet hates PMS.
Old Aug 28, 2012 | 07:28 PM
  #89
ReBilld's Avatar
ReBilld
I knooooww what you mean! Try building one from the frame up.........broke!LOL!!
Old Aug 28, 2012 | 07:31 PM
  #90
fordpride's Avatar
fordpride
Go stage 1.5's
