Tranny problem
Old Aug 14, 2012 | 01:40 PM
Tym's Avatar
Tym
Tranny problem
My '96 F250 7.3L has set still for 2 years. It was cranked frequently and she purrs like a kitten. However, I went to throw it in gear (automatic) and it doens't move, no gear engages, revving doesn't make it chunk into gear and it is full of fluid. Now it is spinning because when I try to put it back in park it makes that awful ratcheting sound you hear if you try and put one in park while it's moving. Any ideas?? Please someone tell me this is something simple?!?!?!?!
Thanks in advance....
Old Aug 14, 2012 | 06:15 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Is it a 4x4? It sounds like the trans is engaging, but the power isn't getting to the wheels. If it is a 4x4 I think the problem is in the transfer case. If not, then I don't know.
Old Aug 14, 2012 | 06:33 PM
rodneywar's Avatar
rodneywar
is the transfer case in gear?
Old Aug 14, 2012 | 06:52 PM
madpogue's Avatar
madpogue
Does the Park position keep the truck from rolling?
Old Aug 14, 2012 | 08:01 PM
fordpride's Avatar
fordpride
Try it in 4H and 4L
Old Aug 14, 2012 | 09:46 PM
Tym's Avatar
Tym
All good points... I'll re-check, but I'm pretty sure it's in 2H. If the x-fer was in neutral I should still be able to go to park without any problems though, right?
Old Aug 14, 2012 | 09:52 PM
jk080's Avatar
jk080
Transmission Rebuilder
You should be able to shift into park but it wont hold, it will roll. If you select a gear like forward or reverse first and then go to park you will hear a ratcheting sound like you mention in your first post.
Old Aug 14, 2012 | 10:13 PM
runthatjunk's Avatar
runthatjunk
Maybe somebody borrowed the driveshaft in the 2 years it been sitting!!!
Old Aug 14, 2012 | 10:16 PM
Mdt1992's Avatar
Mdt1992
defiantly sounds like the transfer case is either in neutral.. or something is wrong in the Transfer Case hopefully the first one
Old Aug 15, 2012 | 09:40 AM
Tym's Avatar
Tym
LOL.... and not too far fetched as someone did borrow the gas outta my boat while it sat over the winter.....
Old Aug 15, 2012 | 04:37 PM
rodneywar's Avatar
rodneywar
it wont roll on flat ground if the disc and drums have rust on them keeps the wheels from turning with lots of friction
Old Oct 4, 2012 | 05:11 PM
Tym's Avatar
Tym
Okay... finally got back it, between work and building the new garage. Turns out the xfer case is in neutral and I can't budge it one way or the other. I got under the truck and soaked it with PB Blaster and tried tapping it in either direction, nothing. So, is this a common issue or just results of sitting for so long and is there a fix? I mean other than oiling, beating, shaking, rattling, heating, etc.... ;-)
Old Oct 4, 2012 | 05:25 PM
BuckHammer's Avatar
BuckHammer
Good call, Mark.
Old Oct 4, 2012 | 05:58 PM
madpogue's Avatar
madpogue
Try pushing the truck a foot or two, just to turn the rear driveshaft a little, and try hand-turning the front driveshaft, just to see if that frees anything up in the T-case to allow it to shift. Otherwise, it may be in the linkage. Can you see from below, whether the detent pin that requires you to push the lever down for Neutral might be stuck on the little block-out plate?
Old Oct 4, 2012 | 07:33 PM
Tym's Avatar
Tym
It is between the detents and up and down movement is fine, but no matter what will not move laterally. I tried the ds and moving the whole truck but I can't turn the shaft or budge the truck. Would hooking it to the F350 and budging it cause a problem, ya think?
