I was installing a home made idle controller and testing it when I heard a pop, then the truck died. No wait to start light. Will crank but wont start. All fuses checked out OK, relays are good but #30 & #31 only getting about 6.5-7 volts. I checked the fuel bowl heater to find that the heater wire was infact broke but was not shorted any where, and the fuse was not blown. Checked the only fuseable link I know of at the coil, it appears to be OK. Is my PCM fried? Worse yet, do you think I fried my ECM? Anyone have any suggestions? Need help!!
You have an IDM...PCM and GEM...
There is no ECM.
Sounds like a possable PCM issue.
Have anyway to try and make contact with the PCM? Data logger or like?
