1 wire alternator conversion
Old Feb 23, 2017 | 09:47 AM
D-rat's Avatar
D-rat
Am sure it's covered here, but am going to tear into the swap this weekend. I have a new wire to run to the battery from the new alternator. What do you do with the existing wiring going to the existing alternator, and which of those wires goes to the ammeter guage?
Old Feb 23, 2017 | 10:50 AM
84espy's Avatar
84espy
On my install, I removed the existing harness for the stock alternator. The one wire was run to the battery with a fuse in between. One thing that I did to make connections easier was to use a battery that had dual post connections. The ones on top and the sides. This made connecting easier and straight forward, IMO. As for the ammeter, someone else will have to chime in as I removed that and ran a voltmeter.
My alternator is 100A and I need to wait about 5 seconds on start-up before the voltmeter reads 14.5V. This is when the belt fully grabs. If you run any higher amperage, you may need to use a two pulley set-up.
Old Feb 23, 2017 | 12:06 PM
redcreekauto's Avatar
redcreekauto
I'm running a single belt set up on a 130 amp with no slippage or squealing. I am not running a high power amp or any high amp draw electronics in my truck though.
Old Feb 23, 2017 | 01:19 PM
D-rat's Avatar
D-rat
the one I have is a 100A unit.
I'll try to follow that wire harness back. Any issues with leaving it tied up someplace so I can keep my old OEM unit as a spare?
Is there anything else I can get rid of with the conversion?
Old Feb 23, 2017 | 01:22 PM
Canus's Avatar
Canus
Check out the Technical Info Hyperlink at the top of this forum.
Old Feb 23, 2017 | 02:37 PM
D-rat's Avatar
D-rat
Those threads are specific to swaps using 3g Taurus and similar alternators. Isn't that a bit different?
Would appear I can pull the full harness and the voltage regulator with this swap though. I got a ammeter guage that's been reworked to be a voltage guage that I assume I just need to tie into a wire that's hot when the truck is running, and that should be it. Seems almost too easy.
Old Feb 23, 2017 | 03:13 PM
F250_Super_4X4's Avatar
F250_Super_4X4
OK so I am confused, are you installing a 1G 100AMP alternator?
Old Feb 23, 2017 | 03:17 PM
D-rat's Avatar
D-rat
Summit racing markets it as a 3g alternator and described it as a ford case with GM guts, and a 1 wire setup.
Old Feb 23, 2017 | 03:24 PM
D-rat's Avatar
D-rat
This is what I bought:
https://www.summitracing.com/parts/tff-7068
Old Feb 23, 2017 | 03:44 PM
F250_Super_4X4
OK got it, so yes you can completely remove the old harness and simply add a new wire with fuse, as you did. You can set the old harness aside or place under the seat in case of emergency. As far as the voltmeter, any ACC source wire will work.
Old Feb 23, 2017 | 03:51 PM
D-rat's Avatar
D-rat
Much appreciated!
Old Feb 23, 2017 | 07:52 PM
maytea's Avatar
maytea
Re 1 wire to 3 wire conversion
If someone (me) already has the one wire as installed by PO, what would be involved in converting over to a 3G setup. Just follow the guides or is there an extra step
Old Feb 23, 2017 | 08:31 PM
PapaBearYuma's Avatar
PapaBearYuma
The 3G needs three wires. Two go to the starter solenoid and the third is ignition switched. I guess that one "turns it on" but I really don't understand the magic-just that it usually works!
I stole this pic from another site-I make no ownership claims or claims of correctness!!!
Old Feb 24, 2017 | 08:51 AM
84espy's Avatar
84espy
If you already have the 1 wire alternator installed, you are good to go. The 3G is short for 3 groove pulley. This was the style alternator to grab and then convert it to the pulleys needed for your engine.
Old Mar 4, 2017 | 02:35 PM
D-rat's Avatar
D-rat
I installed the new alternator and pulled the wire harness and voltage regulator. I HAVE NO ELECTRICS. It would seem the how to forum is a little misleading in that all that wiring can go away. I have a 1 wire setup...its properly grounded and the power goes to the hot side of the battery.
wiring harness thet I removed includes 2 plugs into the harness near the ignition relay, everything from the old alternator, and everything to the voltage regulator. I didnt cut any wires or cut into the harness yet.. Im not using a 3g exactly...its a 1 wire GM setup. Ideas?
