I just installed a four pillar set last Friday and it took us about 4-5 hours. Unfortunately, I received one of the dud fuel pressure sending units so I had to send off for another one but the install went rather well. The one issue I did have occurred with the transmission temp wires. The wires are about half as long as the other gauges so I had to place my Trans temp closest to the dash. I could have added more wire to put the gauge higher on the pillar but I decided against it. I am surprised at how high my EGTs get just driving from San Diego to Temecula. A few decent size hills but not towing anything I was hitting 1100 degrees on some of the hills.
Well I guess I'll get those gauges from riffraff first. Going to set me back 500 (more than I expected) with no performance gain. But safety comes first .
Nobody mentioned basic stuff, like the Hutch mod. We had one member here drop his fuel tank to do a Hutch mod on his EX and found an electric fuel pump in the tank - which nobody here had seen before. If you only have one pair of wires (fuel gauge sender) going to your fuel tank, I would strongly recommend a Hutch mod (maybe a Harpoon mod while you're in there) and installing an external fuel filter with hose and clamps. I had a ton of air in my fuel (poor design on fuel connector to tank) before I did as I suggest here and that shortens the life of the injectors and the fuel pump. FRx would clean up any air that does get into the system. The Hutch/FRx combo gave me a a quieter engine, a litle more power, and improved reliability.
If you chip, the 4" exhaust really helps. If you don't, it won't. Rule of thumb on the 4" exhaust (from my experience): Once you get over 22 PSI boost, you really need it.
I have the Ford AIS intake and it's quiet, but it's a little expensive.
Plugging the red line on the turbo has helped many people, stock or otherwise.
My next mod is to install a recirculating oil filter, to remove the soot from the oil and extend the life of the engine and each oil change.
I have the ISSPRO EV2 gauges. Yes... they are pricey, but I like the alarm feature, they are crazy easy to install, and they match the appearance of the stock dash.
The shift kit will very likely extend the life of the transmission. I lost my stock tranny while doing something stupid and I bumped up to the HD4R100 to prevent the next failure and I learned the proper use of an automatic while towing.
The last link in my signature has helpful information on the 7.3L. I strongly suggest getting everything under the hood to 100% - this helped my fuel economy greatly. I bought AE (with the Ford bundle) and the truck manual to achieve this, but AE is not for the technically challenged. The AE approach is expensive up front, but it has paid me back many times over.
Once these have been addressed, you are truely ready to chip.
It's the way K&N doesn't seal in the OEM filter box that is the problem.
Stewart
I wonder if anyone has ever TOLD K&N about this?? I've heard nothing but bad about their filters for almost 5 years.....even took them out of my gassers after hearing about the problem with 7.3s.....
I'm getting 13.4 (haven't hand calculated yet) mpg according to my truck. I do lot of city and short trips so that probably why. Only mod is the magnaflow exhaust. This sound normal?
There are a lot of things that affect mileage. Everybody drives a little different. You really need to hand calculate it to get an accurate number from what I've been told about the computer monitor in the trucks. I get around 15mpg in my 02 in my signature. On trips it will do better, around 17 or so.
Tugly's post above is right on as to getting the best mileage, and the best running vehicle. A chip may help you, some have noticed an increase, I didn't.
