Sponsored by: Real Truck
4WD?
Old Aug 15, 2012 | 10:43 PM
obiwan kenobi's Avatar
obiwan kenobi
Originally Posted by FordGuy85
I feal like I should have explained myself bwtter here. On your auto hubs, you should have a manual selection. Try to manually lock them. Your front drive shaft should turn. If 4x4 works, then you are not getting any vacume and your hubs are good. If 4x4 is still not working, your hubs are shot.
When I move them to manual, the axle shafts do rotate. However if I spin the wheels with the hubs manually locked and the t-case in 2WD, the front shaft does not rotate if I spin a wheel, should it?
With the wheels off the ground, the t-case in 4WD and the trans in park, the front drive shaft is locked. If I place the t-case in 2WD with the wheels off the ground, the front drive shaft will rotate by hand.
Old Aug 16, 2012 | 05:50 PM
FordGuy85's Avatar
FordGuy85
Sounds to me like your hubs are good. The proper way is to get all 4 wheels off the ground, put the t case in 4x4 and see if they move if front drive shaft is spinning then t case is good. If the hubs are manually locked and not connected to the drive shaft then the hubs are bad. Keep in mind you probably have limited slip or a open diff.
Old Aug 18, 2012 | 06:14 PM
obiwan kenobi
Originally Posted by Lubbockguy1979
When you put it in 4x4 does the a/c go to defrost? If so you have a vaccum leak which could be in the hub its self or a hose or the vaccum pump. The esof hubs are a common issue. They can be rebuilt btw
Checked this today too, AC blew out the correct vents.
MoreBoostPlease
Jan 7, 2023 03:00 PM
CraigK
21
Jun 17, 2010 02:09 PM
RedNeckSuperDuty4X4
Feb 19, 2007 10:15 AM
fornarog
Feb 14, 2006 07:30 AM
