fuel issues
Old Aug 11, 2012 | 03:14 PM
Schickel's Avatar
Schickel
fuel issues
Alright guys i just replaced my fuel pump on my 1977 f250 with a manual 400 in it and i drove it a while and it worked fine then the problems started. At first it would sputter and die on me going down the road and its progressivly gotten worse to the point of now it wont start due to having no fuel (i have a clear filter right before the carb that is definetly empty), so my question is what can i do to fix this problem? Ive heard of putting an electronic pump in line but how does that work with the rest of the system and where can i get one
Old Aug 11, 2012 | 03:26 PM
devino246's Avatar
devino246
Sounds like you have a clogged fuel pickup or clogged line somewhere.
Old Aug 11, 2012 | 03:59 PM
NW 150's Avatar
NW 150
^ my thoughts exactly
Old Aug 11, 2012 | 04:18 PM
mikeo0o0o0's Avatar
mikeo0o0o0
There is a strainer on the fuel pickup that could be clogged. Also check the flexible lines. These get hard and crack allowing the pump to suck air and lose it's prime. There should be three, one at the tank, one mid-way along the frame and the one that hooks the line to the fuel pump.
Old Aug 11, 2012 | 06:13 PM
Blue and White's Avatar
Blue and White
Another possibility is the short segments of rubber fuel line at joints. With time and alcohol they can break down and get so soft the pump sucks them shut. I had this problem... replaced the rubber fuel lines and all was well.
Old Aug 11, 2012 | 07:19 PM
Schickel's Avatar
Schickel
As usual you guys are correct i pulled the line apart and put it in a gas can and she runs great so now i just gotta drop the freshly filled tank :/ and put a better screen on my line and ill be good to go thank you very much
gprust
May 8, 2017 03:10 AM
Scoop531
Aug 26, 2014 08:06 PM
Muddominator
Aug 1, 2011 03:12 PM
89F20plowtruck
May 18, 2010 04:52 PM
fordguy76
Dec 6, 2004 05:34 PM
