body work
Old Aug 11, 2012 | 02:24 PM
rpharesjr's Avatar
rpharesjr
body work
What is better? dipping or media blasting.
What is more cost efficient? I have the cab and bed to do, also the frame.
Old Aug 11, 2012 | 07:31 PM
HIO Silver's Avatar
HIO Silver
Better for what? There are pros and cons for each method.
Dipping removes and eats EVERYTHING that is not metal.. seam sealer, paint, body filler. After it is removed from the vat, ya gotta rinse hit EVERY nook and cranny and then hit it with some kind of rust preventative like an epoxy primer. Some guys will literally pour rust preventative into body channels (like A-pillars and frame rails (for unibody cars)) to stave off rust because it leaves the metal very naked and susceptible to corrosion. For example, dipping the cab will completely strip the cowl assembly and there is no way to get in there with paint unless ya open it up.
Media blasting has better control and is quicker but media blasting has its own challenges - the grit gets into EVERY nook and cranny so ya gotta vacuum, rinse, vacuum, rinse and immediately shoot a protective coat.
Cost effective? If you're attempting a full-on restoration then there is no substitute for dipping... If it's gonna be a clean driver, then I would rather have it media blasted.
Old Aug 11, 2012 | 08:50 PM
rpharesjr's Avatar
rpharesjr
Thanks for the info. I'm looking for a good clean driver. Also I made a couple of calls, and have decided on media blasting. It's a resto with modifications.
RL&C
Apr 24, 2012 07:03 PM
MiaKid22
18
Jul 15, 2011 02:10 PM
RNOVRIT
21
Jul 6, 2007 08:37 PM
army_guy25
Apr 9, 2006 05:59 AM
mallard8767
Paint & Bodywork
Dec 31, 2004 01:01 PM
