QUICK QUESTION..
Old Aug 10, 2012 | 11:09 PM
460 FORD MAN's Avatar
460 FORD MAN
QUICK QUESTION..
What is in the hoses that run from the motor to the heater/ac box on the passenger's side? I starting to pull one off then I saw oil or thats what it looks like.
Will anything leak out when I unhook them from the box?
Thanks guys!
Old Aug 10, 2012 | 11:14 PM
J ballan's Avatar
J ballan
Should be anti freeze in the heater hoses and yes some will leak out.
Old Aug 10, 2012 | 11:16 PM
460 FORD MAN
It's black haha. I guess it's really old.
Thanks man!
Old Aug 10, 2012 | 11:17 PM
J ballan's Avatar
J ballan
Yikes that's scary! Time for a coolant flush.
Old Aug 10, 2012 | 11:23 PM
460 FORD MAN
hahaha, I'm removing the box and plugging the lines on the motor.
Old Aug 11, 2012 | 11:46 AM
AK FORD GUY's Avatar
AK FORD GUY
If it is your coolant lines, from what I have seen, most people just use a section of hose to go from one nipple to the other. That was the coolant still flows through the hose. Not sure if it makes any real difference or not though.
Old Aug 11, 2012 | 02:38 PM
460 FORD MAN
Well I unhooked them last night and had a bucket waiting for coolant to pour out.....Not a drop. I lifted the hoses and yellow liquid came out the rad. drain plug ( I was draining the rad. earlyer and still had the drain plug unscrewed.)
Old Aug 11, 2012 | 03:38 PM
460 FORD MAN
So I got another question..
I'm working on removing my bed today.
What's the easiest way to take the bed off?
What have yall done to take it off with out a engine hoist?
I would use my engine hoist but it's holding up a 302 im rebuilding.
If I undo the bolts can I slide it off from the side?
I was thinking about sliding it off from the back but the gas tank looks like it would be in the way.
What if I drop the tank?
Any ideas or suggestions is much appreciated!
Old Aug 11, 2012 | 03:57 PM
kobaltblue's Avatar
kobaltblue
engine hoist and 2 chains through the center 4 bolt holes.
Old Aug 11, 2012 | 04:15 PM
460 FORD MAN
I would use my engine hoist but it's holding up my brothers 302 i'm rebuilding.
He's being a little girl about putting it on a tire.
I forgot to mention it's a short bed.
Old Aug 11, 2012 | 05:18 PM
460 FORD MAN
Anybody got any other ideas about removing the bed?
Old Aug 11, 2012 | 05:47 PM
keiths78f150's Avatar
keiths78f150
Unbolt. Four strong individuals. Lift. Put down. Drink a beer.
Old Aug 11, 2012 | 07:45 PM
460 FORD MAN
haha thats funny ^.
Well I finally managed to break the 8 bolts on the bed.
Unhooked the gas filler tube.
Is there anything else Im missing?
Where are the wire connectors for the tail lights?
Old Aug 11, 2012 | 07:55 PM
devino246's Avatar
devino246
Behind the taillights. Be sure to remove the grounds too.
Old Aug 11, 2012 | 07:59 PM
460 FORD MAN
Thanks man!
