Body work tips and tricks advice!!!!
Thanks!!!
I have never use Rust Bullet but I think you can directly paint over it without additional product.
On my latest project I am using a two part epoxy prime used to paint outside structures like water towers and bridges, items that are hard to completely clean of rust and are exposed to the elements.
Rust Encapsulator
It's a two part epoxy mastic, POR-15 and the others are one part urethane mastics. POR-15 will start to dry as soon as you open the can. There a few tricks you can use to stretch out the dry time but it will eventually dry in a relatively short period of time. The epoxy mastic I am using it a two part system and will not harden until the two parts are mixed together. It is also about 1/3 the price of POR-15. I bought the two gallons, one the base epoxy and the other the activator, for around $100. After thinning with lacquer thinner I'll have about 3 gallons of the primer to use. POR-15 sells for around $45 a quart around here and over $100 for a gallon. The epoxy I am using is a PPG product and I think it can only be bought in the two gallon kit but it's still cheaper than the POR-15 product.
As for durability, the epoxy sprays pretty easy and also brushes on easily. It dries to a matte finish. I haven't had it exposed to the elements yet but while installing my brake system a good amount of brake fluid has leaked on to the frame and the epoxy was not affected at all.
All of these rust encapsulator type paints are UV sensitive and will faint if exposed for long periods of time to the sun. They'll all fade or get chalky looking but they protection will not be affected.
Also, be aware, you need adequate ventilation when using any kind of chemical like paint or body filler. Don't seal up your "body shop" too tight. You need a lot of air and ventilation. I'd leave two sides open to get a good cross breeze going through the space. Also, if your' going to use a fan for ventilation realize you're passing vapor through an electrical motor that can ignite them.
Seeing as how you have not put your year and model or your location in your post your punishment will be the delusional ramblings of a senile old fart.
In my opinion body work is the most frustrating time consuming insane thing a person can do and practice your drinking because anyone that has done it drinks (a lot).
I admire you ambition and by no means are discouraging you, so go at it, just keep in mind that body work takes much (years) time and practice (years) and get used to doing over, and over again.
There is really no right way, just many that will get the same result. (Not like mechanical stuff) The info that you need should be on some of the paint suppliers web sites, and oh, I don’t like body work.
I used latex gloves as it will not come off your hands.
My 2 cents!
Good Luck!
I have some more body work to do on a few small parts & bought some POR products for those. They sell a body filler that bonds to the POR primer. The also sell a gray sanding primer that bonds to both the POR primer and the body filler.
To put the POR primer on, they advise that you use their cleaner (marine clean) followed by a phosphoric acid wash (metal ready), a water rinse, then the POR primer after the metal dries. So far these steps have worked for me, but I haven't tried the body filler yet....maybe this weekend.
Dan
When it comes to application, we brushed it on. It seemed that it would look like a brushed on surface looks afterwards, but in reality, the next morning - after sleeping through "the high" - EVERYTHING looked awesome. Had some people asked if the frame had been powder coated? I really like this product.
Regarding taking it off your skin once it touches you... FOHGETABOWTIT! I inadvertently laid my head on a drop that somehow spilled (she spilled it) on the floor and reached my scalp - ouch! I had to go get a hair cut later what week - needed one anyway... and as far as the skin, I used one of her foot scrubbing lava rocks - basically rubbed the product AND MY SKIN OFF, but I got it off - while she lived 10 days plus advertising POR15 on her forearm... We laugh about it now.
POR15 hands down is my vote.
Paul
Body work is as much fun or a challenge as you let it be. I personally like to do body work, especially rust repair by cutting out the rotted metal and replacing with new metal. I have never bought a premade patch panel, I have always made my own. I suppose it's a talent like anything else, some people can do it without much thought others are driven nuts by it. Take you time and think it through.
Wear latex gloves AND a pair of brown jersey gloves. The brown gloves will keep torn latex gloves to a minimum and the latex will prevent soaking of the skin.
POR will give you decent results but remember it is not the same as blasting the frame, etc. POR encapsulates the rust, it does not remove the rust. Scuff up a cured patch of POR and the rust will still be there. Also make sure to cover POR for UV protection. I scotch-brite scuff POR and paint over with satin black Rustoleum. POR by itself will get chalky with sun exposure and even frames will chalk over time.
Good luck.
I wanted to chime in on the POR 15 since I have been using it to paint my front end pieces and have been planning to use it on my frame. The POR 15 itself goes on and dries without brush strokes and yes, use gloves - this stuff will stick and not come off. When I get a hole in my gloves I just throw on another pair, in fact it wouldn't hurt to start with 2 pairs on in the first place.
Go by the instructions and don't cut corners with the prep work. In my opinion, a sandblasted part is best to start with, but if you do a good job with a wire wheel, you'll get good results. I had my front end off my truck in pieces, so the smaller parts like the backing plates, spring hangars, smaller sheet metal, radiator stand, I was able to get sandblasted at my local machine shop and bigger parts, such as my straight axle I used my angle grinder with wire wheel.
It's my suggestion that if you go POR 15, use their products to do the cleaning and preparation. I used their marine clean and metal ready to prep the parts, then brushed 2 coats of POR 15, then one (topcoat) coat of their chassis coat. I'm pretty happy with the results. I found that the more porous the surface (such as the straight axle) turn out better with the topcoat then smooth surfaces. On my tie rod and on my radiator stand, the POR 15 self leveled nicely, but when I top coated them by brush, the topcoat did not self level very well (there's brush marks).
I like the suggestion someone had about brushing the POR 15 and then spraying the topcoat, so after all of your hard work, you don't end up with brush marks on those smooth surfaces. I currently plan to do this with my frame - brush the coats of POR 15 and likely get the rattle can chassis coat (POR 15 product) for the topcoat.
I've also used their engine enamel on my brake drums (brush painted after sandblast) - this turned out real well and a paint called "metal mask" (on my backing plates, spring hangers and perches) and this brushes on and dries nicely too.
Good Luck - show us photos!! Joe
Axle photos:
