sensor prob mayb?
Old Aug 11, 2012 | 01:25 PM
johndeeregreen2013's Avatar
johndeeregreen2013
sensor prob mayb?
I have a 2001 f-250 4x4 auto...I only have this problem in the winter...when my truck warms up in the cold morning it makes its usual jet noise out the tail pipe which ik is the flaper behind the wastegate holding the exhaust back to warm the engine...problem is it seams like it never will go off and limits my power..do u guys know of the sensor tha controls that going bad..if so were is it and can I check it to make sure
Old Aug 11, 2012 | 01:28 PM
snakedoc's Avatar
snakedoc
the sensor that in under the turbo controls it.
on my truck i dont see it as long as my dad zf6 stays on for 15 miles.
Old Aug 11, 2012 | 05:41 PM
johndeeregreen2013
From wat I understand whether it is closed or open is determined by oil temp...is that right?...another thing it does in the winter is the rpms will like get stuck at 1400 RPMs and will not go over that rpm but if u put the accelerater to the floor the rpm nver changes but it blows black smoke and RPMs still never chang3 so idk an it only does it every now and agan in thecold winter ...25 degrees or so
Old Aug 11, 2012 | 05:49 PM
johndeeregreen2013
U know I just got to thinking could it b a safety feature for the tranny if the fluid isnt warm enough..the tranny was rebuilt 30,000 miles ago and has a deep pan and 2 stage tq converter
Old Aug 11, 2012 | 06:03 PM
bigb56's Avatar
bigb56
It does sound like your EBPV, a lot of guys just gut them. I chose to keep mine, I resealed the piston and set the preload to spec using a spring scale, works great. I think there may be a way to wire it open temporarily
Old Aug 11, 2012 | 06:07 PM
fordpride's Avatar
fordpride
It's the exhaust back pressure valve. It is designed to help the engine warm up faster when cold. If it bugs you just unplug it. It's a two wire plug under the driver side of the turbo. It's sounds like its working normal to me.
Old Aug 11, 2012 | 06:10 PM
fordpride's Avatar
fordpride
It uses AIT ,EOT, and EBPS to control the exhaust back pressure valve
Old Aug 11, 2012 | 07:25 PM
johndeeregreen2013
Thanks alot guys..iv just moved up to the powerstrokes I use to hve a 6.9 idi so stll workn on understandin the powerstroke...wats AIT STAND FOR
Old Aug 11, 2012 | 07:42 PM
fordpride's Avatar
fordpride
Air Intake Temp
Old Aug 11, 2012 | 07:45 PM
fordpride's Avatar
fordpride
Hers some good reading.
Click on the blue
Ask a Mechanic - A deep look at the 7.3L Power Stroke
Old Aug 11, 2012 | 08:56 PM
bigb56's Avatar
bigb56
That is a GREAT link. Now if I could only afford a scope
Old Aug 11, 2012 | 09:43 PM
johndeeregreen2013
Thanks that link was lots of help and good info appreciate it much
hedhntr
Nov 26, 2012 10:06 PM
hoytfan99
May 21, 2012 04:14 PM
swaybar
Jan 25, 2009 05:35 PM
adamzelazowski
Nov 25, 2008 05:19 AM
ha305
Mar 10, 2008 05:43 PM
