New injection pump
Old Aug 10, 2012 | 11:47 AM
fordguy7904's Avatar
fordguy7904
To dirty diesel would the powerstroke manifolds work on the idi giving the exhaust a short distance to a turbo? If they would your dragster would be easier to plum the exhaust to the turbo like in the pictures with that inline pump
Old Aug 10, 2012 | 03:17 PM
'94IDITurbo7.3's Avatar
'94IDITurbo7.3
PSD manifolds will not work on an idi.
Old Aug 10, 2012 | 03:38 PM
hairyboxnoogle's Avatar
hairyboxnoogle
I think maybe he was referring to the up pipes but im not sure.
Old Aug 10, 2012 | 03:41 PM
'94IDITurbo7.3
custom up-pipe would be way easier.
Old Aug 10, 2012 | 04:18 PM
RacinNdrummin's Avatar
RacinNdrummin
Has anybody actually tried a PSD manifold to see if they will work?? All I've ever heard is that they won't, but the pattern looks to be the same, and its not like they are terribly different engines... I'm betting that they would work with a little modification at the very worst, provided there isn't any major obstructions, like the backside of the head or something...
Old Aug 10, 2012 | 04:50 PM
xcite's Avatar
xcite
PSD exhaust manifolds are longer across the bolt pattern and will not fit an IDI.
Old Aug 10, 2012 | 04:59 PM
fordguy7904
I had to ask on the manifold cuz I found a set at work hidden and were going to get them. Still can wait to see that monster finished
Old Aug 10, 2012 | 05:45 PM
88 Ford IDI's Avatar
88 Ford IDI
Dirty are thinking of having the intake manifold look like the Hypermax idi?
Old Aug 10, 2012 | 07:58 PM
therifleman556's Avatar
therifleman556
Maybe need to make separate tubular intake manifolds for each bank to clear that long pump. Or will the factory manifold fit it? The tubular manifolds would have to meet closer to the rear of the engine...
Old Aug 10, 2012 | 08:27 PM
RacinNdrummin
The stock manifold will not fit, its going to have to be all custom similar to the Hypermax...
If I was Brandon, I would do two separate plenums, both with v-band fittings on the front, and then wye into the charge pipe up front.... It would look super clean, and provide a more even balance between the banks... Much like the duramax banks big hoss stuff...
Old Aug 10, 2012 | 08:45 PM
therifleman556
Would either have to be a high or small "y" to clear the front of the engine unless using e-fans/smaller shroud. I suppose a rear-common intake would use up valuble turbo room. I always thought of doing parallel twins with separate charge pipes (from the intercooler) to individual top-fed intakes.
Old Aug 10, 2012 | 08:50 PM
91dirtydiesel's Avatar
91dirtydiesel
Like this ? "stroked out" 7.3l psd
here is a video of this ^^^^ running....sounds mean lol
http://www.youtube.com/watch?v=zEywPSWAI_8
Old Aug 10, 2012 | 09:03 PM
  #28
therifleman556
Yeah, like that. Are you going to intercool or go higher boost with water/meth injection? Less lag with non-intercooled, but with a drag truck I can't imagine that being a huge concern seeing how you'll probably be doing boosted launches anyway...
Old Aug 10, 2012 | 09:08 PM
  #29
RacinNdrummin
Yes, much like that...
Also you could run a big W/A IC, and run it into an Ice box... Thats what I would do... As well as pump the Water/Meth/Nitrous into it....
Also, you can just mount the radiator in the bed... Easy as pie...
Old Aug 10, 2012 | 09:26 PM
  #30
therifleman556
Well, if we're going to start mounting stuff in the bed, there's plenty of room for a 12V-92 back there..... Just sayin.... The idi could still run the a/c and power steering.
