82 ford
Old Aug 8, 2012 | 05:54 PM
Charlie6831's Avatar
Charlie6831
82 ford
I have 82 f150 4 wd 4.9L 4spd just recently driving and when I put it in reverse trans popped and now it won't go into any gear. What could be the problem
Old Aug 8, 2012 | 07:30 PM
Gary Lewis's Avatar
Gary Lewis
Did it pop loudly, as if something broke? Have you or someone else recently done maintenance on it?
Old Aug 8, 2012 | 07:44 PM
Franklin2's Avatar
Franklin2
Make sure the transfer case is in 2 wheel high. Mess with it and pull it back into 4 wheel high and see if it will move.
Old Aug 8, 2012 | 08:51 PM
Charlie6831
82 f150
It is in 2wd and it wasn't a real loud pop. I tried putting it in 4 hi and low to see if it would pull but won't. It hasn't been worked on
Old Aug 8, 2012 | 10:03 PM
Gary Lewis's Avatar
Gary Lewis
I'm at a loss as to what could cause this. Have you checked to see that the drive shaft is still connected?
Old Aug 8, 2012 | 10:09 PM
Rogue_Wulff's Avatar
Rogue_Wulff
By not going into gear, do you mean you cannot get the shifter into to move, or that the truck simply doesn't move when you put it into any gear?
Shifter going into gear locations, but nothing happens, usually either a clutch disc center broke out OR a broken input shaft in the trans. Both require dropping the trans to repair.
Old Aug 8, 2012 | 10:13 PM
Gary Lewis's Avatar
Gary Lewis
I would think either of those would be a lot more than a small "pop". But, then anything that breaks in the driveline would be more than a small "pop".
Shawn Ertl
Mar 12, 2017 11:34 AM
JoeyB94
Mar 25, 2010 09:37 PM
mudder460
Apr 16, 2007 02:37 PM
71swissaqua
Aug 10, 2001 03:50 AM
