transfercase issue
Old Mar 25, 2010 | 09:36 AM
JoeyB94's Avatar
JoeyB94
transfercase issue
I got a 92 f-350 with the 5 speed in it. My problem is that the transfer case wont go into 4 wheel low. I can pull the lever back into 4 wheel high but then I cant get it to push down to hit the neutral point to pull it back to 4 wheel low. One of my buddies said that the lever needs to be adjusted maybe but I don't see how to do it. Any ideas on what could be wrong with it?
Old Mar 25, 2010 | 09:49 AM
farmert's Avatar
farmert
The lever needs to be lubed up.It moves threw a sleeve type thing that allows a roll pin threw the lever to clear the mounting bracket on the transfer case, when you push the lever down to engauge 4 low. The lever gets sticky where it goes threw the sleve, and it won't travel.
Old Mar 25, 2010 | 10:00 AM
PLC7.3's Avatar
PLC7.3
Haven't driven my truck in a few months but doesn't the 4 wheel low position require the lever be placed forward after pressing down......
Old Mar 25, 2010 | 11:14 AM
JoeyB94's Avatar
JoeyB94
Do I have to take it apart to do it or I can I just do it with the whole thing together?
On mine the manual and the diagram on the lever says to pull it back for 4h then push it down for neutral and keep pulling back for 4l
Old Mar 25, 2010 | 09:37 PM
farmert's Avatar
farmert
You can get to it on the truck, but it might be easyer to remove the shifter from the case to get it freed up. It wouldn't hurt to lube the pivot point on the shifter while you are at it.
