won't go!
Old Aug 9, 2001 | 09:43 PM
71swissaqua's Avatar
71swissaqua
won't go!
My brother-in-law has a 91 f-150 4x4, 302. It will 0nly move in 4 wheel low range. Won't move in any other ranges. He says if you are under the truck when you try to move it(carefully) you can here a kind of jingling coming from the transfer case. Don't these things have some sort of chain drive? Could it be broken? Maybe an easy fix? Can any body gives us any help?
Old Aug 10, 2001 | 03:30 AM
Fordtruxrok's Avatar
Fordtruxrok
won't go!
Is the an adjustment on the high low lever linkage, if so have you adjusted it??. If there are no problems with the linkage, chances are it's internal in the trans case.
John
Old Aug 10, 2001 | 03:50 AM
panhandle's Avatar
panhandle
won't go!
