Hard shifting
Old Aug 7, 2012 | 07:49 PM
1997fordf350's Avatar
1997fordf350
Hard shifting
Hi when my truck shifts from 1st to 2nd it shifts hard I haven't tried it on any of the other gears yet but my dads truck had the same problem but it was just a fuse? Is this something bad?
Old Aug 7, 2012 | 08:11 PM
Toplait's Avatar
Toplait
Check for Codes.
Replace the VSS sensor in the Rear End. Anti-Lock Brake Vehicle Speed Control Sensor.
Clean out the TPS. Throttle Position Sensor.
Check the wiring.
Check this forum page out it may help.
https://www.ford-trucks.com/forums/1...st-to-2nd.html
Old Aug 7, 2012 | 09:04 PM
Si11ynood1er's Avatar
Si11ynood1er
What about the transmission fluid level? I would add some lucas transmission fix, even if it is not leaking. It helps with hard shifting.
Old Aug 9, 2012 | 11:52 AM
1997fordf350
How do you check those things and I checked the fluid and its full.
Old Aug 9, 2012 | 03:08 PM
rla2005's Avatar
rla2005
Is the speedometer erratic? Some good info for how to test the VSS in this thread: https://www.ford-trucks.com/forums/1...-problems.html
Old Aug 9, 2012 | 03:16 PM
1997fordf350
No it's fine and how do I test it and where?
Old Aug 11, 2012 | 04:52 PM
elee3's Avatar
elee3
My 95 had this problem, and it was a broken 1 to 2 shift accumulator spring. Maybe the same for you. I found a thread somewhere about it. It may have been f150online.com
pipeorgantuner
Oct 12, 2011 06:12 PM
aholtum
Dec 5, 2010 05:53 PM
zamunda
25
Jan 31, 2010 03:12 PM
bohiaa
May 1, 2006 09:21 PM
Bowcop
Sep 23, 2005 06:11 PM
