The last few days it has been shifiting erradicly(sp) I will be going along at say 35 mph turning about 1500 rpms and it will suddenly shift down with no increase in throttle from me..
What gives??? Do I have a sensor problem or something else.
The only thing I have done to the rig in the last few weeks was put a differant exaughst system on it.
Besides the obvious broken wires loose connection.no but if you pull the sensor out of the rearend and it is covered in gray particles of metal think about a fluid change soon.you can get a new sensor pretty cheap! might as well have one in your hand before removing.
Rich
I want to make sure I am looking at the right plug. In the front center of the rear diff is a black flat plug that has wires in it that go to the front of the truck. Am I on the right one?
