Trouble continues
Old Aug 7, 2012 | 11:27 AM
nintey4f150's Avatar
nintey4f150
Trouble continues
Ok so it starts n runs and drives around fairly decent.. I am havin an issue with my tps but while cruising around in drive I give it full throttle and it doesn't really do anything no acceleration kinda jus bogs around 3000rpm but If I start out in first gear and hit it it pulls to 5500 then I shift to second an same thing so what could b the issue with it not accelerating in drive wot.. Tps? Idk
Old Aug 7, 2012 | 03:21 PM
adam.hilberath's Avatar
adam.hilberath
Sounds more like it possibly could be in the transmission...how many miles are on it?
Old Aug 7, 2012 | 05:39 PM
rla2005's Avatar
rla2005
You are more or less are working on the same issue, please stick to one thread so others can see what has already been suggested and completed.
https://www.ford-trucks.com/forums/1...ps-sensor.html
Old Aug 7, 2012 | 06:46 PM
Toplait's Avatar
Toplait
I would say TPS....IF you got a code reader it will tell you if that is the problem.
Old Aug 8, 2012 | 04:50 AM
nintey4f150
just wanted to let everyone know that yes it was a faulty tps sensor
Old Aug 8, 2012 | 07:49 AM
rla2005's Avatar
rla2005
Glad you found the problem. Did you try measuring the old one to see if the output was funky? It may measure good at closed throttle but many times the output is non-linear or the maximum output is significantly below maximum (~4.5VDC). Either of the latter conditions will never trigger an error code.
Thanks for replying back with the fix!
Old Aug 8, 2012 | 08:43 AM
nintey4f150
No didn't measure it.. Noticed that the tabs inside of it were broken when I took it off so it had no way of knowing I was on the gas
ResJudicata
Jan 7, 2016 09:52 AM
claythetreeguy
Aug 20, 2013 04:22 PM
rollerstud98
Jan 2, 2013 03:13 PM
TUFFY
Jan 1, 2011 08:59 PM
Silentst2000
22
Jul 5, 2005 07:33 PM
