A/C problem
Old Aug 6, 2012 | 04:35 PM
Powerstroke-7.3's Avatar
Powerstroke-7.3
A/C problem
I have a early 99 f250 4x4 and i have noticed that when the a/c is on my fan does not blow on the lowest setting but it works when i just have the vents on. All the other settings work fine. Anyone out there have this problem?
Old Aug 12, 2012 | 04:00 PM
1fixitman's Avatar
1fixitman
The resistor for the lowest setting is blown. Replace Switch to repair.
Old Aug 12, 2012 | 10:16 PM
carltonwebb's Avatar
carltonwebb
Negative. Replace the resistor. It is under the hood next to the blower motor and less than $20.
Old Aug 12, 2012 | 10:34 PM
1fixitman's Avatar
1fixitman
Calrtonwebb is absolutely correct. I was very tired and meant to say Resistor instead of Switch. Advance auto has a few exact fit items if you want to look. I do not know how much a stock ford part cost for this. Go to Advance Auto Parts: Car, Engine, Batteries, Brakes, Replacement, Performance & Accessories and add your vehicle. Then type in Blower Motor Resistor to find what I have posted below.
Dwayne
Advance Auto Parts: Search Results for blower motor resistor
I forgot to mention that the resistor is just to the right of the blower motor and directly behind your Air conditioning Dryer as viewed from the passenger side with the hood open against the firewall. Carefully remove electrical connector from blower motor resistor and remove the two bolts holding it in. It is recommended to remove the negative cable from your battery to replace this item. I guess I really need to go to bed. Good evening.
Old Aug 13, 2012 | 09:12 AM
Powerstroke-7.3
Thanks for the help guys. I'll get into it this weekend
Old Aug 13, 2012 | 06:33 PM
carltonwebb
[quote=1fixitman;12160163]Calrtonwebb is absolutely correct. I was very tired and meant to say Resistor instead of Switch.
It happens to everyone. I kind of figured that but did not want him to order the fan control switch in the cab in the meantime. That is nice description on how to find and replace it. I was tired too which is why I only posted as little as I did.
dfiske
34
Nov 27, 2013 12:32 AM
Jgbxfd
Escape & Escape Hybrid
Jul 7, 2011 07:27 PM
zedex
Nov 11, 2009 07:26 PM
jcee
1983 - 2012 Ranger & B-Series
Nov 17, 2008 05:19 PM
JoshF250
Dec 22, 2006 08:06 AM
