1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Lifting a 2011 250. Best kit for the DYI'er?
Old 08-06-2012, 07:15 AM
Clover_SD's Avatar
Clover_SD
Clover_SD is offline
Hey guys! I have a 2011 250 SD crew cab 4x4 6.2L gas. It currently has the stock 18" rims on it with the stock origional tires. By the time I need new tires I want to get some 20" wheels and also do a lift. I don't take this truck 4 wheeling I just want the look of a raised truck so I guess a body lift is my best option. Here is what I am looking for.
- 2-3" lift without affecting suspension, "much".
- A complete kit or list of a kit and other peices I will need.
- A kit I can do myself in my garage. I am a pretty compotent shade tree mechanic so i know my way around tools.
- Something that won't hurt gas milage to bad.
- I pull a 34' travel trailor so I need to be able to do that. I have a drop receiver setup so increased truck height won't hurt me as I can lower the hitch point.
- Lastly "I think", where to buy?
Current mods to the engine are: Cat back single exhaust, AFR stage 2 intake. no tune. I am looking for options on that as well if anyone has any suggestions.
Thanks
Wade
Old 08-06-2012, 09:22 AM
2000silverbullet's Avatar
2000silverbullet
2000silverbullet is offline
How big of tires are you looking to run and what's your budget?
You can get a leveling kit and some 35" tires fairly inexpensively. Leveling kits can be as basic as spacers in the springs to brand new springs, again, depends on your budget.
Once you level it, when you get the trailer hooked up, depending on the tongue weight, it might point the truck's nose into the air. If so, some air bags/timbrens/add a leaf would alleviate that.
For tuners, go with Mike from 5 Star.
Old 08-06-2012, 09:31 AM
Clover_SD's Avatar
Clover_SD
Thanks! I don't really want to go crazy with a lot of money and mods. I just wanted to raise the ride hight a bit. I know that adding 20's will accomplish some of that but not sure it will get it where I am wanting it or think I am wanting it. I think air bags start to get into money I don't really want to spend.
I am not really familiar with lift kits but have heard the terms body lift and suspension lift thrown about with the body lift being the easier, cheaper route for those of us looking for the raised look but not really concerned with the performance increase of off roading.
Does this make sense??
Thanks
Wade
Old 08-06-2012, 09:46 AM
2000silverbullet
Wheels won't add any height, it's the tires (sidewall) that add the height. All the big name suspension company's make leveling kits, plus there's some others that you can piece together off of eBay, etc. I have a ReadLift leveling kit in my garage waiting to get installed. It has spring spacers, shock extensions, and a new trackbar bracket. I keep the factory springs and my current shocks with this setup. I couldn't (and wouldn't) recommend a body lift. Maybe someone else with more experience with those will chime in.
Air bags are about $250-$300 depending on where you get them, and you could probably install them yourself.
Old 08-06-2012, 11:00 AM
Clover_SD's Avatar
Clover_SD
Thanks. Your kit sounds like something that would work for me. Does it raise the ride hight on the front to match the back or does it raise both ends? What tires are you planning to go with?
Old 08-06-2012, 11:06 AM
Tylus's Avatar
Tylus
Tylus is offline
MMNC (SS)(Ret)
2-3" leveling kit
F-350 4" blacks
Leveling kit goes ontop of your front coil springs. Maintains your factory ride
f-350 blocks replace your 2" blocks
You'll gain 3-4" of height with no change in ride quality. This will let you run 35" rubber. Looks damn good IMO.
Also, run the F-350 blocks to offset your trailer weight. It'll let your truck squat some without pointing the noise skyward
Old 08-06-2012, 12:31 PM
2000silverbullet
Tylus pretty much cleared it up. My truck with a 2.5" leveling kit should set it close to level where the same kit on your truck may make it sit higher in the front. It all depends on your front spring configuration, but the rear blocks on the 350 are taller than that on the 250..
I'm going with a Toyo M/T in a 285/75/18 on my factory rims. These reflect on Toyo's site at 35.1" tall and 11.6" wide.
Old 08-06-2012, 12:41 PM
Clover_SD's Avatar
Clover_SD
Old 08-06-2012, 01:00 PM
2000silverbullet
Yup, looks good.
fordf2501
04-15-2016 09:54 AM
AndeyHall
26
03-06-2010 07:02 AM
shark1979
03-10-2009 04:46 PM
ashleymc
2004 - 2008 F150
07-03-2007 03:53 PM
generalee31184
2004 - 2008 F150
06-27-2007 11:41 PM
Quick Reply: Lifting a 2011 250. Best kit for the DYI'er?
