bouncing problem
Old Aug 5, 2012 | 10:04 PM
Schickel's Avatar
Schickel
bouncing problem
Alright boys and girls i took my 1977 f250 with a 400m in it to a truck pull today and entered in the small block class, i started bouncing like fifteen feet after i let the clutch out. Now i didnt break thanks to the old ford durability but how on earth do i get over this problem?
Old Aug 5, 2012 | 10:13 PM
Schickel's Avatar
Schickel
Well its hapening under the load of 30000 lbs while i spin the tires on the track she hops
Old Aug 5, 2012 | 10:14 PM
crazy96863's Avatar
crazy96863
I noticed a bit of bounce in my car... I did a tune up and the bounce effect went away. While I was thinking something with the clutch was going wrong, it was really the lack of the appropriate amount of power from the engine.
Not sure if this helps or not but it could be one cause. Maybe motor mounts also? Bad clutches usually straight up slip don't they?
My truck bounces if I ease the clutch to much; it seems to behave better if I simply drop it. I just try and make sure I am not doing so @ 4k or something stupid.
Old Aug 5, 2012 | 10:23 PM
460 FORD MAN's Avatar
460 FORD MAN
IMO I was thinking you need more weight in/on the truck. I'v seen trucks do tug-a-war and bounce around. But I dont know what kind of ''bounce'' your talking about.
Old Aug 5, 2012 | 10:25 PM
crazy96863's Avatar
crazy96863
I thought you were referring to a bouncy or jerky feeling in the clutch... Plz disregard.
Old Aug 5, 2012 | 10:34 PM
460 FORD MAN
Reddog's Pullin Truck Forum: How to get bounce out ?
Read that it should help.
Old Aug 5, 2012 | 10:50 PM
HIO Silver's Avatar
HIO Silver
Better known as wheel hop....
1. Reduce rear tire pressures
2. Traction bars or traction links
Old Aug 6, 2012 | 01:48 AM
bamaf150's Avatar
bamaf150
Does it shudder or bounce/shake if you ease off in granny gear?
Old Aug 6, 2012 | 02:33 AM
460 FORD MAN
Is the whole truck bouncing?
Old Aug 6, 2012 | 07:08 AM
Schickel's Avatar
Schickel
As far as i can tell its starts in the front and then causes the rest to hop as well
Old Aug 6, 2012 | 10:09 AM
HIO Silver's Avatar
HIO Silver
Adjust the shocks for significantly less rebound... they're acting like pogo sticks and then it starts oscillating.
savage250
Jan 24, 2012 05:15 PM
meier63
Sep 28, 2011 08:59 PM
chevyman20
Dec 2, 2010 04:35 PM
smangold
Apr 2, 2006 03:33 PM
BigBrownTruck
Mar 26, 2000 12:02 AM
