Starting issue
Old Aug 5, 2012 | 04:43 PM
nickw059's Avatar
nickw059
Starting issue
1977 f150 460 4X4 Hey guys, hoping you can shed some light on my problem! Yesterday I was flushing the radiatior, I got my distributor wet, I cranked for like 10 seconds and stopped. I let the starter cool off and cranked for another 10 seconds, after I let off of the key the truck continued cranking so I pulled off the battery connections. than reconnected them, now it wont crank at all, since the starters are cheap, I replaced it, still wouldn't start, I checked over the starter solenoid, it works good, but i'm not getting power at the ignition switch wire on the solenoid. I jumped the solenoid (jumped by sending 12 volts to the ignition wire post ) and it cranked and fired than a second later the starter kicked in again while the truck was running! It made a horrible noise! where should I go now? Do you think I have 2 seperate problems? All fuses are good.
pittdog1977
Jul 11, 2014 05:11 PM
floppywater
Jan 2, 2011 10:17 PM
78BigBlock09
Mar 30, 2010 02:48 PM
chopped&dropped
Apr 3, 2009 10:48 AM
Texan58
Jul 28, 2006 10:34 AM
