1978 - 1996 Big Bronco
Should I?
Old Sep 16, 2012 | 10:30 PM
  #46
88rustyred's Avatar
88rustyred
I looked at that Sky Manufacturing site earlier today and i think i saw a 5" heavy duty shackle. But i thought you said they said not to add anything to the shackle kits or it'll throw the pinion angle off
Old Sep 16, 2012 | 10:31 PM
  #47
ManfredVonRichtofen's Avatar
ManfredVonRichtofen
Skyjacker® FLFR36 - Ford Bronco 1984-1990 Leaf Spring
Look at this....
I can't believe it..$120 for two pairs of 6" lift springs? Too good to be true?
NVM BRONCO II grrrr
Old Sep 16, 2012 | 10:38 PM
  #48
88rustyred's Avatar
88rustyred
GO FOR IT! I think thats even cheaper than the shackle kit. Plus you know its made for your vehicle, not something a ton heavier
Old Sep 16, 2012 | 10:46 PM
  #49
ManfredVonRichtofen
It was for a Bronco II...YEAH...it was a big bummer when I scrolled down after I posted on here and saw what it was for. Dang it.
I just contacted this guy about his shackle flips...they look nicely built.
Shackle Flip Kits - FSB Forums
Old Sep 16, 2012 | 11:07 PM
  #50
88rustyred's Avatar
88rustyred
I only read the 1st page. but it looks like he makes them for 6" lifts also.
Old Sep 16, 2012 | 11:17 PM
  #51
GruesomeJeans's Avatar
GruesomeJeans
Those things you asked about, don't they kind of resemble the plates that go on top/bottom of the coil springs? I am not sure on the rubber things though. The kit looks ok, what kind of springs are those? Yeah the shackleflip is only 4 to 4.5 inches BUT you can add to it if needed. From what i have read it acts just like your old spring shackles but lipped over. You are going to have to adjust the Pinion Angle even if you go another route because the 6" difference from the t-case to the differential will play havoc on your u-joints.
The 250 springs should work ok for your bronco, like 88 mention, make sure they are 3" wide. The only issue i foresee with using those is it will be a hell of a ride going over bumps. Unless they are thinner leaves. A new set of 4" Superlift leafs for my bronco are around $500 before shipping. I think 250 for some used one is ok as long as they arn't damaged.
Old Sep 18, 2012 | 05:56 PM
  #52
ManfredVonRichtofen
I'm probably going to do a shackle flip. I should still be able to tow my stuff...I'm still trying to figure out though...
Old Sep 18, 2012 | 09:06 PM
  #53
ManfredVonRichtofen
I'm thinking about just going to a solid front axle.....still thinking....as usual.
Old Sep 18, 2012 | 11:40 PM
  #54
GruesomeJeans
The decision is ultimately up to you, i don't know the pros and cons of SA versus TTB in towing so i can't say much. The only thing i really know is the camber on a TTB gets offset when the front of the truck is lifted so the outer edges of your tires would get worn faster as your towing. But like i said i don't know much on towing for either.
Old Sep 19, 2012 | 09:43 PM
  #55
ManfredVonRichtofen
Well the SAS would take more money vs me going and getting shackle flips (if I can find a good pair for a good price). Would love to do the SAS but I don't have a welder to do any mods.
Old Sep 20, 2012 | 01:58 AM
  #56
GruesomeJeans
A welder? For a SAS? Interesting.
Old Sep 20, 2012 | 05:48 AM
  #57
ManfredVonRichtofen
Yea. Read some threads where guys had to weld on the track bar mounting piece.
Old Sep 20, 2012 | 10:59 AM
  #58
GruesomeJeans
Ah yeah I suppose that's important. When I lift TGM if I am required to drop the bracket I will consult my neighbor and see what he thinks. He has experience with lifts and welding so his opinion would be nice. Same with the radius arm mounts.
Old Sep 21, 2012 | 09:39 PM
  #59
ManfredVonRichtofen
I know im ready to lift my bronco though..just dont knw if i need to do sas or wait and do it. And still stuck on shackle flips or springs...
Old Sep 21, 2012 | 10:56 PM
  #60
BrO-J's Avatar
BrO-J
I run a junkyard shackle flip in the rear and F250 springs, front SAS is fairly simple. Shackle flipping does give the bronco a tad bit more body roll but nothing bad, I would suggest also looking at a BDS lift kit
http://bds-suspension.com/bar Full springs or an add-a-leaf are better than blocks but they all work just fine.
Here is my front shackle but my rear is identical. I used an F250 hanger that I pulled from the junkyard.
