1978 - 1996 Big Bronco
Should I?
Old Sep 16, 2012 | 03:14 AM
  #31
88rustyred's Avatar
88rustyred
Thank you Gruesome. That's what i was trying to think of. I think that's exactly what Manfred needs. And it'll keep the axle centered in the wheel wells, too. I'll have to remember this when i do mine.
Old Sep 16, 2012 | 04:26 PM
  #32
GruesomeJeans's Avatar
GruesomeJeans
No problem. This is what I plan to use when I lift my truck. Unfortunately there is some drilling you have to do on the frame for the mount relocation, but it shouldn't be an issue.
Old Sep 16, 2012 | 07:07 PM
  #33
ManfredVonRichtofen's Avatar
ManfredVonRichtofen
Here is the kit I got from a dude off of here..
What is all of this for? Looks like I need to get a new rubber piece for them (you can see one old rubber piece)
Just wire brushed some of the parts and painted em..
Old Sep 16, 2012 | 07:41 PM
  #34
88rustyred's Avatar
88rustyred
COOL! You got new radius arms! They usually come in the deluxe kits. Glad to see that you got the extended front brake lines,too. (the radius arms would'a looked better painted in florescent green)
Old Sep 16, 2012 | 07:42 PM
  #35
ManfredVonRichtofen
Florescent green...hm?
I've found some 6" lift springs but they fit a f250. Will they work on my bronco? He wants $250 for em.
http://valdosta.craigslist.org/pts/3276426630.html
Old Sep 16, 2012 | 08:06 PM
  #36
88rustyred's Avatar
88rustyred
Don't take my word for it. If the length, measuring from eye to eye is the same, they should work, as long as yours are 3" wide. I dont know about the perches(where they sit on the axle) But the'll look good in green too
Old Sep 16, 2012 | 08:25 PM
  #37
ManfredVonRichtofen
What about 4" leaf springs? Is the stock block on the Bronco 2"?
Old Sep 16, 2012 | 08:39 PM
  #38
88rustyred's Avatar
88rustyred
I just went outside and looked at mine [86 bronco, built 9/85]. its got wedges between axle and springs. But i think thats for the pinion angle
Old Sep 16, 2012 | 08:48 PM
  #39
ManfredVonRichtofen
True. That's right....
That shackle flip yall mentioned....
It's only 4". They said if you add anything else to it that it might mess up the pinion angle..
Old Sep 16, 2012 | 09:47 PM
  #40
88rustyred's Avatar
88rustyred
Sounds like you may need those 6" 250 springs. $250 sounds a little steep for used springs. Are they fairly new, or kinda old. I'd check Rocky Mountain Suspension, at least for price comparison.
Old Sep 16, 2012 | 09:49 PM
  #41
ManfredVonRichtofen
they want $250 for front and rear springs
Old Sep 16, 2012 | 09:56 PM
  #42
88rustyred's Avatar
88rustyred
Oh,ok. I thought it was just the rear set. Will he separate them? (just buy the rear) Or do you hafta buy all four?
Old Sep 16, 2012 | 10:10 PM
  #43
ManfredVonRichtofen
buy all four. I don't know if I want to do that or not...I'm still wondering...I don't know what to do.
Old Sep 16, 2012 | 10:17 PM
  #44
88rustyred's Avatar
88rustyred
Do you think you could sell the front springs after buying all four?
Old Sep 16, 2012 | 10:22 PM
  #45
ManfredVonRichtofen
No. Probably not.
That 4" shackle flip, plus the add a leaf I have, you think will make it 6"?
