Radiator coolant
Thank you.
We need to tone this one down.
Beechkid, in no way do I see Greystreak being a paid blogger and trying to sell a product based on that, however I can see why you would be upset if that happened on these forums. None of us want to waste time looking at advertisements, we come here to get knowledge and help, and I can guarantee Greystreak isn't try to advertise a product for money. He'd be doing it because that's what has worked best for him, and based on the information I've seen him post, he knows a LOT about these Broncos.
So we can all agree to disagree or have more friendly arguments so we can all be happy and kind and benevolent
!! I think we all have more important things to do than get mad over each other based on what someone typed on their computer that we will most likely never meet or see!ANYWAYS... back to the topic of this thread, I believe what it comes down to is that:
- If you use full strength antifreeze, use ONLY distilled water, not tap water or well water etc.
- If you use the 50/50 mix, you can fully fill your radiator with that and be mostly good. Possibly add more distilled water during summer, and more pure antifreeze during winter, or just keep it all 50/50
- If you are using distilled water, there are products you can use to prevent corrosion and beechkids posts provide more info on that
- If you fully flush out your system, you can switch to Evans coolant which is quite expensive, but is supposedly an excellent product and has very good reviews, prevents corrosion, and runs at a lower pressure then normal antifreeze. It is a lifetime product so once it's in you don't need to change it. Also its non-toxic so those with animals won't have to worry about accidental spilling when doing coolant maintenance.
In my opinion, it's easier for me to run to the store to get some antifreeze and distilled water, and if you use those and flush your system yearly, you will be in good shape. However, I may try to find the very small coolant leak I have and fix it up, then switch to Evans because I'm liking the way it sounds. But for now, I may stay with 50/50 coolant because it's cheaper initially, but not in the long run, and I have 5 cats and 2 dogs so any accidental spilling is pretty bad.
it is more effective................because if has a much higher boiling point
There is no need to inspect the internals of a cooling system
this is based off of only one item of reference, company marketing materials
let's take the boiling point for example...I do not doubt the elevated boiling point of the product as compared to "Conventional Coolant", but, if an engines max operation temp is 240 (let just say for discussion purposes), does having a boiling point or effective cooling spec of any liquid do any good even if it is effective at 400 degrees....of course not, because the fluid will still heat up to and past 240 degrees and engine damage will still occur......so the fact that the coolant can exceed that capacity by x times, has no benefit.
"There is no need to inspect the internals of a cooling system"- ie waste of time, or because the system is sealed there is no corrosion or contaminents entering the system, ...
well, inspecting the cooling system for contaminents provides early indicators of identifying upcoming component failure......leading to prevention or mitigation of potential damage. If you take a basic ph test of your coolant in a "sealed system" it is a 99% chance (statistically) you will find the ph is not 7.1, any variation of this is an indicator that "contaminents" exists and a chemical reaction is occurring.
So where is the 'cost effectiveness"....there is none, where is the "waste of time", there is none nore are there any references as required by the forum rules as referenced.
Well, ask the folks who are running Bassani exhaust, because of the quality, the longevity and the fit. Ask the folks who opt to spend the extra money on a Tuff Country suspension lift because their lift is the ONLY one to incorporate additional alignment provisions for TTB trucks. Ask the folks who run Sylvania Silverstars even though they know they have a shorter life expectancy because they truly do produce a bit more light. Spend more than a week in this forum making a scene simply because you cannot accept that someone MIGHT have more or better information than you do. And yes, every one of the products listed above I have touted at some time or another because the question was asked, "What works best for you?" and I answered truthfully, with facts and actual product usage experience backed up with research information pertaining to the systems and components employed. But ya know, I guess all it takes is some arrogant know-it-all to show everyone in the forum what a terrible ******* I've been for the last ten years and how I've duped them all into ruining their vehicles with my suggestions.
Moderator, I really think this posting needs to be close......I really can't understand the furror.....
I just looked in my radiator on my Bronco and it is all mucky and rusty, I tried flushing it out with a water hose the best I could.
Thanks in advance.
Grey said what he uses, 2 other members asked for information on the Evens as well as OP asking opinions on what people use, Grey responded to the thread with what he uses and why.
He isn't directly selling the product, just gave info and his personal experience and what others have experienced using Evens, which was asked for by other members.
You did the same with ethylene-gylcol based coolant & distilled water. BUT with a condescending post towards Grey as if what he uses isn't as good.
Just the way I see it.
ffice
ffice" /><o
></o
>http://www.corrosionsource.com/(S(cylzjm45pkvkle45ywzhvn55))/FreeContent/1/Cathodic+Protection#BOOK1<o
></o
>The anode needs to have a common connection with the metals it's protecting. This is exactly what the marine world is doing, the anode is directly attached to the metal it's protecting. In the automotive case, I think just grounding the anode would suffice since the engine block is already grounded as well. The radiator you may want to check for a common ground with an ohmmeter. The antifreeze solution itself is no substitute for a common connection to the anode for the block and radiator.<o
></o
>What does anyone think about that ?
If I mis-understood or interpreted, I apologize.....
however, the laws of physics & chemistry have not changed in 100 years, by my trade (R&D/Vulnerability Assessment), I simply stated that people should judge a product by known scientific standard, not PR/media materials.
