Help with stalling problem
Old Aug 4, 2012 | 03:37 PM
04WVPSD's Avatar
04WVPSD
I posted the other day about the problem with my 04 stalling due to what I believe was a voltage problem. I have checked a few things and am still having the problem. Truck will run fine for awhile (maybe 10 min, maybe 2 days) but then will stall. first indication I have is dash gauges quit working then shortly after the truck will stall. If I let it set for 10 min or so It will start right up like normal and may run for 20 min or 2 days. Hard to tell. I have cleaned, tightened etc. all batt terminals. Batts were replaced recently (within the last month due to another problem). Alt is about 1.5 years old. Havent had it tested so it could be the problem but doesnt seem to be. If anyone has any further insight, please let me know as I am getting very discouraged.
Old Aug 4, 2012 | 03:44 PM
BLADE35's Avatar
BLADE35
Have you checked the grounds theres more than just the 2 off the Batterys
smaller ones that come off the frame to the CAB
Old Aug 4, 2012 | 03:51 PM
04WVPSD's Avatar
04WVPSD
I have only checked the one that comes off of the pass side battery and bolts to the fender well by the pass. battery. I also did not unhook and clean the ground wires from the batt that hook to the frame but am preparing to do so this evening when it cools down or early in the morning. I have people telling me that it may be the computer but I do not believe this (or dont want to I guess). I will start hunting down grounds I guess and clean and check them.
Old Aug 4, 2012 | 04:19 PM
BLADE35's Avatar
BLADE35
Yes clean them Main grounds that come off the Batterys on goes by the A/C Compressor and the Other goes by the power steering PUMP make shure to clean BOTH ENDS at Battery and where they mount to truck
and theres a few Little grounds all over going from frame to Cab ect......
Have you scanned for DTC????????????
Old Aug 5, 2012 | 12:46 PM
04WVPSD's Avatar
04WVPSD
OK. Update time. Scanned for DTC's and none were found. Did this with the SCT tuner since I do not have access to scan gauge. Before I started working this morning I tried to start truck and batts were dead. cleaned all ground terminals I could find, on all ends and hooked everything back up. Jumped truck off of Navigator and of course it started right up. Batt voltage before jumpers were attached was around 12V. Surely not enough to start. Truck ran untill jumpers were taken off then instantly died. Once I left them on enough to get a good batt charge I unhooked jumpers and tested alt with the little function on my battery charger. It failed. Headin to town to have it checked at auto parts store. Hopefully this will get me running again.
Thurston243
Apr 4, 2019 07:16 PM
1Austin112
May 10, 2016 05:11 PM
badstuff
Aug 31, 2007 06:54 PM
badstuff
Aug 31, 2007 04:02 PM
Ducktruck
1997 - 2003 F150
Dec 9, 2006 11:50 PM
