Voltage Dropping
Old Apr 3, 2019 | 02:02 PM
Thurston243's Avatar
Thurston243
Voltage Dropping
Hey guys and gals I am having a weird issue with my 1996 f-150 and I was hoping someone here might have a solution. Sometime when I go to start my truck right after it starts the volt gauge will bounce around ,under half, and sometimes it gets low enough it kills the truck. To keep it running I have to feather the gas and it helps keep the volts up till it quits bouncing around. The weird thing about this is it doesn't do this all the time. has anyone run into this before or has a solution I'd appreciate the help.
Old Apr 3, 2019 | 05:17 PM
Conanski's Avatar
Conanski
Sounds like a ground problem, check both battery terminals for corrosion and also the main battery ground at the frame.
Old Apr 4, 2019 | 09:07 AM
Thurston243
I've checked the battery terminal already but did check the frame. Thanks for the suggestion i'll check it out.
Old Apr 4, 2019 | 09:30 AM
subford's Avatar
subford
The frame ground is only used for the trailers use.
The frame is not used as a ground for the engine or anything in the cab or the bed.
Sounds like a bad alternator brushes to me.
Old Apr 4, 2019 | 07:16 PM
Thurston243
oh okay thanks for the info I'll look into the alternator.
Vernon Myers
Feb 21, 2016 05:28 PM
1NiceHarley
Mar 23, 2015 04:12 PM
fordfaninIL.
Electrical Systems/Wiring
20
Nov 19, 2006 11:55 AM
Cruiseomatic
Nov 7, 2004 06:01 AM
71FoMoCo
Oct 6, 2003 05:26 PM
