Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Air Intake and Exhaust Guides
- Exhaust Modifications
Overview of popular modifications to customize your truck
EcoBoost Modifications
Keep your tires inflated to max areas of the rating. Best mileage and load hauling there. Level your truck for the load your hauling, less wind resistance. Lots of guys going down the road with a late 60's front end rake up in the air just sucking down fuel. If your truck isn't level hooked up to the trailer add. If you want a truck for tow/haul set it up that way, instead of like a car. Next trip to the Dealership go with a stronger set of axles to do the mountains. You can always lower the ratio with bigger tires. RPM's will help clean out the CAC and deliver to the road needed torque. It actually gets better the more trailer tow option you do. Crisp shifts, higher gear change RPM's and downshifts for hills and stop signs. All pullout the condensation and give added braking/torque at the road. Many want a car that works like a truck or vise versa instead of a truck that works and drives like a truck. That's ok for the average guy going to work every morning. Not you I know, you want a truck that pulls and hauls like a truck, not a overloaded and sway backed out to pasture.
This is what you want on your 12 ta 13 EB. 2012 3.5 Ecoboost AFE Stage 2 Intake Kit - 5 Star Tuning and independent air to each turbo with equal air pressure.
desert2013f250
04-11-2014 01:15 PM
