glow plug cost
Old Aug 3, 2012 | 12:23 PM
Donzi Dude's Avatar
Donzi Dude
glow plug cost
What us the approximate cost of having a glow replaced?
Old Aug 3, 2012 | 02:41 PM
BLADE35's Avatar
BLADE35
The Glow Plugs in these are GOOD ones and dont normaly Fail
If there is an Issue sometimes its the GPM
If you have a DVM you can test the GP
The GP is like $10.00-$15.00
The Kicker is the Glow Plug Harness usually Breaks upon removal
Theres also 2 diffrent sizes what year is the truck???
What is the Drivability Concern????
Old Aug 3, 2012 | 05:56 PM
cheezit's Avatar
cheezit
its about 2 hours labor per side and diag time, plus parts.
Old Aug 3, 2012 | 08:21 PM
98SurplusExpy's Avatar
98SurplusExpy
Plan on ordering a harness ... I just did my RH bank and every one broke, tool or no tool.
Old Aug 5, 2012 | 07:35 PM
Donzi Dude's Avatar
Donzi Dude
Asking because my son found a 06 he wants to buy.
It has a check engine light light lit, the guy scanned it and says the code says that the glow plug on #1 is not working.
The truck starts and runs fine.
Old Aug 5, 2012 | 08:58 PM
98SurplusExpy
I did the entire RH side this weekend, including the harness, for about $90 in parts (Ford parts at that). The #1 cylinder is on the RH side ... so as I did, you may as well plan on changing the whole side & harness (the old harness WILL break).
Old Aug 6, 2012 | 04:45 AM
Yahiko's Avatar
Yahiko
Before you spend time and money on a new
glow plug and harness try this.
Remove the Glow Plug Control Module. Clean the contacts
with contact cleaner both plug and sockets. Next apply some
of the dielectric compound and reinstall. Test the system again.
Mine is an 06 and if I clean under the hood for some reason I
always get water in the plug and I get a light. This little process
fixes the problem then you can just clear the code. I hope the next time I
do any under hood cleaning I will not have the error with a good coating
of dielectric compound. Also If you have it unhooked you can wit the pin out
check the plugs with you VOM or DMM (same thing mostly).
Sean
Old Aug 6, 2012 | 07:17 AM
Donzi Dude's Avatar
Donzi Dude
Sean
Thanks that may be the problem because the truck was detailed.
Fandini
Mar 3, 2013 10:52 PM
rlandrum
Nov 5, 2011 02:22 PM
sullyt28
Jul 27, 2010 07:38 PM
ifurlong
Feb 18, 2010 11:22 AM
79beater
Dec 6, 2004 09:24 PM
