ignition problem
Old Aug 2, 2012 | 08:50 PM
bigfoot7180's Avatar
bigfoot7180
ignition problem
i have a 78 f150 with a 74 351c.until recently no problems with how it runs.it developed a high rpm miss.today it just up and died.replaced coil module and battery.only get fire from coil when i first hit key then no spark.anyone ever have this happen before.any ideas besides burning it lol
Old Aug 2, 2012 | 09:35 PM
fmc400's Avatar
fmc400
MSEE
This means the module is not switching the coil on its own. Either the pickup in the distributor is bad, the ignition module is bad, the wiring in between the module and the pickup is bad, or the module is not getting power.
Old Aug 2, 2012 | 10:24 PM
bigfoot7180
how do i check the pickup.also i was told check fusiable link at selenoid bypassed to check same thing.al though it backfired when i let off key.sounded like a f*n bomb
Old Aug 2, 2012 | 10:30 PM
fmc400's Avatar
fmc400
MSEE
If the engine is cranking at all, you're getting power to the solenoid which means the fusible link is fine.
To check the pickup, disconnect the distributor and measure the resistance between the ORANGE and PURPLE wires coming from the distributor; it should be between 400 and 700 ohms. Neither wire should have continuity to ground.
Old Aug 2, 2012 | 10:34 PM
460 FORD MAN's Avatar
460 FORD MAN
Originally Posted by bigfoot7180
all though it backfired when i let off key.sounded like a f*n bomb
HAHA, thats funny!
Old Aug 2, 2012 | 10:40 PM
bigfoot7180
thanks fmc400.yes it cranks fine and only has a spark at the coil when you first turn the key.460 it was funny after i changed my underwear lol
Old Aug 2, 2012 | 10:54 PM
460 FORD MAN
...lmao!!!
Old Aug 3, 2012 | 09:33 AM
bigfoot7180
pickup coil measured fine not getting a signal on the tack side of coil?
Old Aug 3, 2012 | 10:41 AM
bigfoot7180
when i first try to start it .it has 1 light redish orange spark then nothing.also on bat side of coil key on not cranking voltage is around 4 when cranking its about 8 maybe 9.
Old Aug 3, 2012 | 12:40 PM
fmc400's Avatar
fmc400
MSEE
You've eliminated the pickup, now move on to the other things I told you.
That voltage is too low; it should be 6 to 7 volts in RUN and 10 or so in START. What voltage do you get across the battery posts?
Old Aug 3, 2012 | 12:51 PM
crazyeddie's Avatar
crazyeddie
Sounds like a faulty Duraspark module BUT follow fmc400's advice - I have learned a lot from that gentleman!
Before you bust out the multimeter though, take a look at your duraspark module - if there's epoxy running out the back of the module onto your fender apron, odds are it's toast. I fried a few in the past by not using the correct ballast resistor with my coil.
Old Aug 3, 2012 | 12:58 PM
bigfoot7180
i had full voltage at the battery.im thinking i might have gotten a bad module.
Old Aug 3, 2012 | 01:01 PM
bigfoot7180
i have verified power to module i ran a continuity test on the wires none broken.cleaned all connections and in run position have around 7.5 volts to coil and little over 10 cranking.thanks for all your help fmc400
Old Aug 3, 2012 | 07:50 PM
bigfoot7180
i'm a moron i shouldve pulled cap and turned engine over.rotor not turning broken timing chain.thanks for the help fmc400 i appreciate it alot
Old Aug 3, 2012 | 10:10 PM
fmc400's Avatar
fmc400
MSEE
No problem, sorry to hear about the timing chain.
Bruce in SC
Apr 26, 2026 06:53 PM
sixofspades
33
Dec 25, 2023 10:28 PM
sixofspades
Feb 14, 2014 08:23 PM
Spooky
Sep 16, 2003 03:13 AM
Graffe
Jul 28, 2002 01:10 AM
