MSD Ignition question
Old Jul 27, 2002 | 10:34 AM
Graffe's Avatar
Graffe
Old Jul 27, 2002 | 07:32 PM
76_F150_390's Avatar
76_F150_390
Could someone tell me if a MSD 5 igniton module would totally replace my stock igniton module (duraspark)...I don't have any spark and can't seem to locate the problem so I think I will replace my whole ignition system (except dist. and pickup coil)
Old Jul 27, 2002 | 07:53 PM
thelonerangerxlt's Avatar
thelonerangerxlt
76, yes, it will replace the Duraspark module. The pick-up coil inside the distributor causes a lot of no-spark conditions, so make sure that it is good. Also check the black wire going into the distributor. It is the only ground wire for the ignition.
78 Bronco Ranger XLT, 351M, 4-sp, Trailer Special
Old Jul 27, 2002 | 08:26 PM
76_F150_390
thanks for the help
I already did check the pickup coil...the right amount of resistance and right amount of peak voltage - the only thing that it might be is the ground.
Also, is there anyway I could test to see if my ignition module is bad???
Old Jul 27, 2002 | 09:10 PM
Mike W's Avatar
Mike W
There is a procedure in the shop manual for testing the Duraspark. I would just go ahead and use the MSD.
Old Jul 28, 2002 | 01:10 AM
TorqueKing's Avatar
TorqueKing
the MSD 6A box rocks even harder, full CD multisparks for 20 degrees of crank rotation until 3000 RPM, and the primary voltage is 450, talk about a hard-hitter! It still replaces everything, and it's just as easy to hook up, but it's about $35 more. Just something to think about. TK
'77 F100, 302 (the aftermarket Prodigy), C4
Cadet Second Lieutenant John F. Daly III
South Carolina Corps of Cadets, The Citadel
The TorqueKing
