Very Disappointed
Old Aug 2, 2012 | 07:31 PM
72Highboy4x4's Avatar
72Highboy4x4
Very Disappointed
Heres the story. About 4 months ago i had the 360 in my F250 rebuilt. I had alot done to it and sunk around $7k into it all together. Last week i finally got the correct pushrods and everything was coming together. Today i went in to a friends shop and hooked it to the dyno. Before starting anything he asked me if i had a guess. I told him, with a huge smile, that i had no idea but expected the HP to be in the 350-400 range and the TQ to be closer to 450+. On the first run i blew the tread off the back tire and had to get my only spare put on. On the next run everything worked flawlessly but we only got it to 4600 rpms before it coughed and had to back off. The next run went to 4700rpms and that was it. I looked at the screen in complete disbelief, running 4700rpms hitting 104mph and a dismal 380 TQ and 279 hp at the wheels. I am dumbfounded. Neither of us expected to see what the screen revealed. I still cant believe it and im ready to sell this dam* truck now. Needless to say im really bummed and i had to tell someone.
Old Aug 2, 2012 | 07:57 PM
jacks61ford's Avatar
jacks61ford
there can be a ton of variables of y the numbers are down like retarded timing chain from a smog model or carb size base timing distributor not curving correctly
Old Aug 2, 2012 | 08:01 PM
Twistedwrench's Avatar
Twistedwrench
The 360 was never a high horsepower engine , those numbers are pretty respectable actually . I wouldn't be upset with that ..
Old Aug 2, 2012 | 08:10 PM
BobbyFord's Avatar
BobbyFord
Not trying to be a jerk but the 360 is a turd for HP. Good pulling motor but not too good HP-wise. For $7K you surely could've gone with a 390 rotating assy. or even a stroker.
Old Aug 2, 2012 | 08:41 PM
jacks61ford
for 7k could have had a 450hp 347 crate motor but that's boring haha
Old Aug 2, 2012 | 08:42 PM
elgemcdlf's Avatar
elgemcdlf
Pretty rough to say anything without knowing what you have done to the engine. I would think 400 hp along with your guessed torque would be expecting quite a bit out of a 360. I have 100 more cubic inches & am probably between 350 & 400 hp.
Old Aug 2, 2012 | 08:51 PM
jacks61ford
I spent 2500 and my 5.0 on the engine dynoed 498 at 4500 rpm but the only thing stock is the block that being said fe motors are not high performance nothing with out a set of good flowing heads as any ford engine all have asthma have the the heads ported and polished or aftermarket... heads can be bolt on 50 to 60 hp on a stock motor . does n e one make aftermarket heads for 390 360 motors?
Old Aug 2, 2012 | 08:58 PM
BobbyFord's Avatar
BobbyFord
Are you saying a tunnel port 427 isn't high performance?
There's no replacement for displacement.
Old Aug 2, 2012 | 09:16 PM
jacks61ford
427 are the exception 7k wouldn't buy a empty block lol 428 runs like a beast too but again very pricy I'm talking common motors but I love my fe motors just the way they r
Old Aug 2, 2012 | 09:24 PM
BobbyFord's Avatar
BobbyFord
For less then $4000 you can have a stroked 445" FE with Edelbrock aluminum heads. Forged pistons will be a bit more.
Old Aug 2, 2012 | 09:43 PM
elgemcdlf's Avatar
elgemcdlf
Originally Posted by instig8r63
...There's no replacement for displacement.
AMEN! If I had the money I would have a Kaase 820 cid hemi.
Old Aug 2, 2012 | 10:18 PM
72Highboy4x4
All the mods are listed in my garage, but its a modified 390 now bored .030 over with forged pistons and ported heads, oversized stainless valves and big cam, roller rockers etc. Check it out if you want to, like i said, its all in my garage
Old Aug 2, 2012 | 10:38 PM
elgemcdlf's Avatar
elgemcdlf
Big cam, roller rockers, ported heads, oversize valves. What is the rpm range on the cam? What is the rpm range on the intake? Early or late timing set? Have you had a real carb man set up the carb? What ratio on the rockers? Were the heads ported by a Ford builder or ???? I know it is real easy to ruin a set of 385 series heads if you don't know what you are doing. Comp ratio? What is the casting number on the heads? I assume you are aware that Edelbrock makes a cam matched to your intake.
Have you read this?
http://www.network54.com/Forum/74182.../Reversion+Dam
http://www.google.com/#hl=en&sclient...w=1024&bih=685
Old Aug 2, 2012 | 11:58 PM
orich's Avatar
orich
I look in your garage and it look like you put the 7k all over the truck and not just the motor. Unless you had a hurry shop do it all for you. You may just need to have it tuned right & jetted, Plus the motor may still be a little tight. But sounds like somethings not right, sure you'll find what you did or the problem...
orich
Old Aug 3, 2012 | 12:03 AM
HIO Silver's Avatar
HIO Silver
Waitaminute..... you ran the rig on a chassis dyno, right? Those results can vary widely from dyno to dyno PLUS... that's rear wheel horsepower. The numbers you hear from people may result from an engine dyno or a chassis dyno so it needs to be an apples to apples comparison.
An engine dyno does not experience parasitic driveline losses like a chassis dyno. For example, an auto tranny is inherently less efficient than a manual transmission which transfers more HP to the rear wheels. Using the rule of thumb of 20 to 25 percent for parasitic losses, your estimate of 350 is in the ballpark for gross HP at the crank. An 380 ft.lbs. at the rear wheels is also decent.
The RPM is only 4700? That's low if, as I am assuming, it has a higher lift cam. However, ya might have found the line between lift/duration and how much the stock heads can handle.
