trans pan??
Old Aug 2, 2012 | 10:16 AM
mojoman's Avatar
mojoman
Question trans pan??
hello folks...I run a '95 f250 4x4 ec...the PO advised a "heavy duty" Ford was installed a year previous to my purchase...question...is there any way to ID the heavy duty Ford trans by physical features like pan shape etc???
thanks guys!!!
Old Aug 2, 2012 | 10:31 AM
DIYMechanic's Avatar
DIYMechanic
There is only one automatic transmission that was put into these trucks, the E4OD. If it has been made "Heavy Duty" it wasn't by Ford, and all the changes are internal (triple disk converter, heavier clutches and planetary gears, upgraded valve body, etc). There's not really anything you can tell by looking at it from the outside. You're just taking the guy's word for it and if he said it was from Ford, them my guess is that it is a stock transmission. The only thing they could have done was to put the latest version of that transmission in the truck, which had a few improvements over some of the early designs, but my guess is that it is a stock E4OD.
Old Aug 2, 2012 | 01:41 PM
Awitte58's Avatar
Awitte58
thanks guys!!!
Nate is right, but I am curious if you mean the trans pan or the actual Transmission?
Your title says trans pan, but it sounds like you are talking about the actual transmission.
But yes if Ford re-did the trans I would assume it to be a stock one...
I dont know why if a trans fails that you would take it back to the place that put it in. Id try elsewhere searching for a trans I couldnt break!
I know that wasnt you. Im just a professional ranter.
Old Aug 2, 2012 | 01:57 PM
fordpride's Avatar
fordpride
Ford does offer a HD E4OD trans as a replacement
Old Aug 2, 2012 | 03:06 PM
DIYMechanic
Got details?
Old Aug 2, 2012 | 03:16 PM
Talyn's Avatar
Talyn
Far as I understand the 7.3 had the HD E4OD, and the gassers had a standard E4OD. Even the 460 had the standard.
But that's my understanding of it, I could be wrong.
Which I probably am in this case.
Old Aug 2, 2012 | 04:08 PM
fordpride's Avatar
fordpride
I just got off the phone with a buddy at Ford parts department. If you got a E4OD from ford it was the HD verson. The only difference is it has(his words) a so called better TQ which is junk and they changed the springs in the VB for a better shift which didn't help.
Now on the ad they offer a standard verson and a HD
Old Aug 2, 2012 | 04:57 PM
mojoman's Avatar
mojoman
thanks guys...I dunno what transmission I have...but appreciate your responses...)
Nhull97
Sep 14, 2014 08:13 PM
str8racing
Jan 17, 2010 08:10 AM
brooksstls
Feb 6, 2007 11:45 PM
water 5
Mar 11, 2006 01:11 PM
7.3burnoutbuddy
Feb 24, 2006 06:21 AM
