E40D trans pan
Old Mar 11, 2006 | 09:44 AM
water 5's Avatar
water 5
Question E40D trans pan
Anny body know if a E40D trans pan replacement is a dealer part only can't finde stock replacement.Plus did a trans service on my 94 F-150 4x4 and the dam thing leaking and i bought the rubber gasket kit too not the cork so the trans pan was a little wavy around the bolt holes.Torque all the bolts down and it leaves a 3'' spot.
Old Mar 11, 2006 | 09:57 AM
quicklook2's Avatar
quicklook2
try national parts depot, link on left.
Old Mar 11, 2006 | 10:36 AM
water 5's Avatar
water 5
no luck they had a after market b/m no stock pans.
Old Mar 11, 2006 | 12:33 PM
quicklook2's Avatar
quicklook2
try bronco grave yard, lmc.com, even advance.com.
or go to the junkyard and find one.
Old Mar 11, 2006 | 01:11 PM
water 5's Avatar
water 5
I will check those site out. the pan i have now is this common for a pan to leak like this on rubber gasket or go back to the cork gasket and put silicone on?
