fuel lines keep brakeing at the injectors HELP
Old Aug 2, 2012 | 07:12 AM
cals70mach's Avatar
cals70mach
1994 IDI 7.3 replaced motor 7 months ago and now I keep breaking the hard lines that go to the injector’s. they are breaking on top of the injectors. 3 deferent lines 1 line 2 times there is no clamps on either side please help<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
Old Aug 2, 2012 | 08:48 AM
farmert's Avatar
farmert
You NEED the dampner clamp on the lines, or you will continue to break the lines from the vibration from the engine. A visit to a salvage yard should get you a set.
Old Aug 2, 2012 | 06:53 PM
kobaltblue's Avatar
kobaltblue
Originally Posted by cals70mach
1994 IDI 7.3 replaced motor 7 months ago and now I keep breaking the hard lines that go to the injector’s. they are breaking on top of the injectors. 3 deferent lines 1 line 2 times there is no clamps on either side please help<!--?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
DESETOF8 Set Of Injector Lines For 1983 - 1994 7.3L IDI & 6.9L Ford Diesel Trucks Only
M-13546 Injector line clamp (4 line assy) For 1983 - 1994 7.3L IDI & 6.9L Ford Diesel
M-13548 Injector line clamp (3 line assy) For 1983 - 1994 7.3L IDI & 6.9L Ford Diesel
M-13543 Injector line clamp (2 line assy) For 1983 - 1994 7.3L IDI & 6.9L Ford Diesel
Old Aug 2, 2012 | 06:55 PM
kobaltblue's Avatar
kobaltblue
Old Aug 2, 2012 | 08:38 PM
akamacgyver's Avatar
akamacgyver
Clueless spectator!
I could call this guy for you,
Ford 7.3L Diesel International 1988-1997 F250 F350 E250 E350
and see if he'll sell just the injector lines and clamps. They are light so shipping shouldn't be too bad. Let me know.
Old Aug 2, 2012 | 10:37 PM
whiteboyslo's Avatar
whiteboyslo
Wow, those look way easier to deal with than the stock units. I have such a hard time getting everything to line up and end up dropping the nut in the intake valley a million times.
Mike
Old Aug 3, 2012 | 12:18 AM
cals70mach's Avatar
cals70mach
they look like there to wide youed haft to open the lines wider i went to FORD and my parts guy helped me out
Old Aug 3, 2012 | 03:59 PM
kobaltblue's Avatar
kobaltblue
They fit like there suppose to, I have them on my drivers side of the engine and soo much easier to deal with NO flippin floppy nut falling down on to the intake pan 15 times to deal with.
Old Aug 3, 2012 | 04:29 PM
eatont9999's Avatar
eatont9999
Mike
Yeah, that's what I thought when I saw them. The stock ones are a real PITA with that bolt. If someone was smart, they may be able to weld the bolt in place on the stock unit. Too bad I don't have a welder.
pawayne63
Nov 8, 2016 07:31 PM
1994F2507.3L
May 10, 2010 09:30 AM
mabc926
May 7, 2010 10:15 AM
BlueOvalBud
Mar 27, 2010 04:00 PM
texasjack
Jul 28, 2008 08:37 AM
