Recommended Code Scanner
Old Aug 1, 2012 | 07:40 PM
SoCar72's Avatar
SoCar72
I'd like to purchase a code scanner for my '92 5.0L which is still the stock SD EFI system. What scanner do you guys recommend?
I plan to (sometime in the future) upgrade to a MAF system using Ford components. Would the MAF upgrade require a different scanner?
Thanks.
Old Aug 1, 2012 | 08:31 PM
norfolknova's Avatar
norfolknova
Just save some money and do it the inexpensive way, use a piece of wire and gound the singal wire you would plug into a scanner and count the blinks of the check engine light.
Matt
Old Aug 1, 2012 | 08:32 PM
burnout400m's Avatar
burnout400m
Matt
You could do that, but for $25 this makes it easier.
I've used this one on my '89 F150 and my '90 F250 and I like it.
Amazon.com: Equus 3145 Ford Digital Code Reader: Automotive
Old Aug 1, 2012 | 09:39 PM
Evan_P's Avatar
Evan_P
Old Aug 2, 2012 | 12:08 AM
tschrubb's Avatar
tschrubb
^--- what he said. It might take an extra 30 seconds to count and double count (if needed), but it's easy and cheap.
Old Aug 2, 2012 | 12:54 AM
mr.fordneck's Avatar
mr.fordneck
GET THIS ONE. Seriously, it's not worth it counting flashes
Old Aug 2, 2012 | 09:53 AM
subford's Avatar
subford
Note the Equus 3145 Ford Digital Code Reader is not a scanner and will only display codes. It will not output data to read or transfer to your home computer.
Data would be temp readings of the transmission, engine, distributor adv while running and so on.
You asked about a Scanner and the Scanner I have is the Actron Scanner CP9190-9185.
I also have two of the Equus 3145 Ford Digital Code Readers that I use when I just want to read the codes.
Yes either the Equus 3145 Ford Digital Code Reader or the Actron Scanner CP9190-9185 would work for both systems.
Old Aug 8, 2012 | 07:07 PM
SoCar72's Avatar
SoCar72
Excellent info. Just what I was looking for. I'll look into either the Equus or Actron. I'm a data nut, I may go for the Actron.
Thanks!!
command37
Feb 22, 2016 08:35 PM
Mbizzal
16
Aug 13, 2015 07:11 AM
92snowplower
Apr 11, 2011 06:25 PM
jr27
General Automotive Discussion
Oct 18, 2006 01:38 PM
JBronco
1978 - 1996 Big Bronco
Sep 7, 2006 07:48 PM
