Highboy frames
Old Aug 1, 2012 | 06:56 PM
b money's Avatar
b money
Highboy frames
Ok I want to swap a 12 valve into a highboy, my basic goal is to have a sled pulling truck that is geared for highway use. So I'm wondering if the F250 and F350 highboy frames are the same? I don't care about the suspension as I'm going to change it anyways. I got a lead on a 72 F250 that is in good shape supposedly that the owner wants to get rid of. Would that be any good for my plans?
Thanks
Old Aug 1, 2012 | 07:05 PM
impalaslayer's Avatar
impalaslayer
Thanks
a 72 is actually a bump side but the frames will be the same as a 73-77 highboy.
as to your question about a HB being the same frame as a f350, your answer is no. the HB as a unique frame.
im building a 76 HB with a 12v right now, check out my build thread
Old Aug 1, 2012 | 07:18 PM
mark a.'s Avatar
mark a.
In the 4x4 the f350 didn't start till '79 and it was considered a low boy. I'm not so sure that a dent side body will bolt right on to bump side frame if thats what your planning ? Frame widths are different in the high boy from the cab back. I'm sure someone will come along with that imfo though.
Old Aug 1, 2012 | 07:49 PM
b money's Avatar
b money
Oh ok I so I guess I'll have to go with an f250 highboy, I thought you could get 4x4 on both 3/4 and 1 tons. As far as swapping bodys I don't plan on it I just mentioned the 72 because I found a deal on one but I like the body style of 73-77 whatever year I get I'll most likely stay with that body.
Old Aug 2, 2012 | 07:18 AM
Blackfoot Big Block's Avatar
Blackfoot Big Block
The wheelbase on a 1972 would be 131" for a standard cab truck. In 1973 the wheelbase was increased slightly to 133".
I don't know definitively that the frames are different, but I'd recommend taking some measurements to ensure the 1972 frame will work. My suspicion is the frames are slightly different.
Old Aug 2, 2012 | 11:41 AM
1972RedNeck's Avatar
1972RedNeck
You should put a link in your signature so it is easier to find
Old Aug 2, 2012 | 12:49 PM
ChaseTruck754's Avatar
ChaseTruck754
Last I checked they don't let you do that here. I tried with the build thread on my crew cab a while back &it was a no-go...
Old Aug 2, 2012 | 03:26 PM
impalaslayer
lame.
didnt realize there was a 2 inch difference in wheel base, ive never owned a bumpside, they are quite rare around here and have only ever seen one for sale.
Old Aug 2, 2012 | 06:13 PM
b money's Avatar
b money
So what year(s) would have been the strongest of the highboy frames?
Old Aug 2, 2012 | 07:19 PM
1972RedNeck
My suspicion is that the springs are not centered on the '67 - '72 highboys (the hole in the rear springs is ~ 2.5" ahead of center IIRC).
It might be the front springs too though. I can't remember. I thought that the frames were identical.
Old Aug 2, 2012 | 08:02 PM
impalaslayer
pick one..
exiled
Nov 12, 2007 06:34 PM
83stepside32784
Aug 17, 2007 06:32 AM
buzzbait65
Aug 17, 2003 06:41 PM
John Pen
Jun 6, 2003 01:34 PM
