Temp gauge max's/ DTC
Old Aug 1, 2012 | 02:33 PM
540milotalon's Avatar
540milotalon
Not my truck. '05 550 6.0 Temp gauge went to max after a 15 min road trip and trouble codes are P0117 Engine coolant temp circuit low, P0528 Fan speed no signal and P1464 A/C out of test range when we do KOEO or KOER. I tried the sticky's and a search but no help. Suggestions?
Old Aug 1, 2012 | 03:05 PM
npccpartsman's Avatar
npccpartsman
Check the fan and temp sensor harness between the upper hose and fan shroud.
Old Aug 11, 2012 | 07:32 AM
540milotalon
OK, after some search time we found that Ford had a TSB on these things for the clutch fan replacement when throwing theses codes. We picked up a new one but yet to install. The truck will not go 5 miles cold start ( ambient temp was *90) before the A/E shows 240+ temps when plugged up. Owner had T stat changed and the mechanic that changed said the truck heated right up to max temp on gauge. Are we now looking at bad water pump? With these closed systems I don't see how you check water flow.
Old Aug 11, 2012 | 08:05 AM
bismic's Avatar
bismic
Are you sure the coolant temperature sending unit has not failed?
What is the TSB number for the one you referred to?
Old Aug 11, 2012 | 09:38 AM
540milotalon
I will go by the truck and get the TSB printed by Ford and post later. The truck never boiled over even with a spike on the laptop of *247. I counted that as a good coolant mix. It may very well be a sending unit. With no pressure on reservoir cap and no boil over makes sense. A simple mechanical gauge or infrared tester could help with that I'm thinking. THANKS
Old Aug 11, 2012 | 09:51 AM
bismic's Avatar
bismic
Also, the oil temp sending unit and the coolant temp sending unit are the same. They can be swapped (as a test method).
Old Aug 11, 2012 | 02:06 PM
540milotalon
The TSB # is 07-03-10 that the Ford service tech gave us. Will try to swap sensors this PM.
Old Aug 15, 2012 | 11:03 PM
540milotalon
OK Bismic- Mark? I swapped the sensors and plugged up the A/E and the truck started with engine oil temp @ 157* and coolant @ 88*. Coolant rose to 191* and oil temp went to 301* and truck was running bad, did not want to go. Finally found a sensor (Ford did not have it, had to order, NAPA said the closet one in Indiana, we're in Va.) and installed it and cleared codes. Coolant temp started @ 76* and oil @73*. Ran truck 1/2 hour at highway speeds and temps were coolant 189.XX* and oil temp 203.XX* Truck ran pretty good. I'm still driving a OBS 7.3 and this thing has power!! Brought it back and turned it off and found no codes, just the generic stuff it tells you when nothing wrong. The A/E works better every time I use it, like maybe it needs breaking in. Thanks again, really guys. With no codes the friend will probably take the unopened clutch fan back for refund.
Old Aug 15, 2012 | 11:08 PM
bismic's Avatar
bismic
good deal!
sullybear23
Jan 8, 2018 09:17 AM
DIYBob
1983 - 2012 Ranger & B-Series
Oct 1, 2017 07:01 AM
tcatrider_99
Aug 26, 2014 06:40 AM
CPaulsen
Modular V10 (6.8l)
Sep 24, 2011 05:11 AM
Fulltimer50
6.7L Power Stroke Diesel
17
Aug 22, 2011 09:46 PM
