Bad Turbo??? (pic)
Airaid filter installed (cone type).
So, my first gut instinct says the fins are damaged but I don't see any damage on the compressor housing. The previous owner must have had a happy day with a can of spray paint because the housing is blue. So, at a minimum, the housing was removed for the paint job but I can't help but wonder if maybe the wheel was replaced at the same time. Is there an aftermarket wheel that looks like the photo below?
Seems very similar to an OEM wheel but the notches on the blades seem unnecessary...So, I suppose there are three possibilities...
- The compressor wheel is aftermarket, brand unknown...
- The wheel is OEM but the blades are damaged by contact with the compressor housing. Then, the previous owner replaced the housing but not the wheel (doesn't seem a very likely scenario...)
- The OEM wheel is damaged by dirty air, dusting. I've seen some threads on the internet about this issue but am not sure that a dusted wheel would be so symmetrical.
Blow by is normal. Wheel spins fine. I have noticed that the engine builds boost much faster than my pickup trucks do but I figured that may be due to the weight of the truck, rear gears or Big Head wastegate.....(or maybe a combination of factors).
Here is a photo. The top pick is Alvin (my F250 DD truck). The bottom pick is Simon (F-450 RV hauler). Should I be shopping for a new wheel? If so, do I need a WW or will the OEM wheel be ok still? So far to date, I have not experienced turbo surge (or whatever it's called...)
Thoughts...???
... very early stages, but none the less. Here is a link, scroll to the second page, you will find a picture that looks just like your wheel. http://www.motorcraftservice.com/vdi...argerGuide.pdf
I would probably run a stock wheel given the option.
Could the notching be from housing contact if the boost was high enough to move the wheel out along the shaft axis?
The notches are very symmetrical, almost as if the blades were machined down a little bit....sorta like what would happen if it contacted the housing...
So, what causes that exactly? Excessive boost, worn thrust washer etc? I have zero play when I grab the nut with my fingers. I guess I need to get in there with a pair of pliers and give it a real tug....
Is that the best method to check the condition of the bearings etc? I guess I am wondering if I get a replacement wheel and my housing isn't all torn up inside (because it may have been replaced already....), then is it reasonable that I might have a simple fix by just replacing the compressor wheel?
With luck the housing will be ok.....however I am not going to hold my breath. I can see this turning into PMS-fest real quick.
My injectors are off with Rosewood right now anyway so 2 weeks will be just about perfect. He usually turns them around in 1 week but not always...just depends on the work load I guess. I sorta knew something like this was going to happen. It can't be just a simple injector swap because that would be to easy. Nooooo, have to make it more complicated whenever possible. I tested my coolant and the strips show about 60% antifreeze when it needs to be about 50/50 so I need to get that back in balance. But why do that when I can have ELC for $100-$120? So, I'll be doing Gooch's flush procedure. Since I'm doing that....might as well rebuild the oil cooler since I have the kit because you KNOW that thing will start leaking as soon as I put ELC in the block... Murphy's Law gets me every time....
