flywheel in my 87 F-250 shot, of course i cant find a new one so my mechanic thinks we may be able to put one from a 7.3 into it, same number teeth on flywheel but .... is this do-able ????
Sorry I missed the specifics of your post the first time I read it the other day. Supposedly the (87 only) 6.9. and the 7.3 IDI flywheels are one and the same.
ok I'm a little confused (what else is new)was swapping the entire clutch does with and 88 7.3 a problem because so far, (about 40 miles) is hasnt been one ???
yup. if it has a ZF trans it is dual mass. if it has a 4 speed it is single .
but it is very easy to put a single flywheel setup on a ZF trans truck, and commonly done to get away from the problems of the dual mass.
