Bad starter?
Old Jul 30, 2012 | 08:22 PM
MikeRizz's Avatar
MikeRizz
Bad starter?
Went out to run to the store in my 03 V10 X and no start. Things I have checked:
Battery voltage is fine ( 12.6 VDC at battery while turning the key )
Tried using a jump pack just to make sure
Tried starting in neutral
Tried wiggling shifter
Banging on starter
I can hear the starter make a click sound when the ignition is turned all the way. I assume the started is DOA?
Old Jul 30, 2012 | 08:39 PM
Red97350's Avatar
Red97350
I would say it sounds dead. You could always take it out and have it checked at an auto parts store. Hope this helps.
Red
Old Jul 31, 2012 | 10:04 AM
LX Sport's Avatar
LX Sport
Check the short wire from the solenoid to the starter motor. It is down on the starter. Clean and tighten. You should remove neg from battery before you check it.
Old Jul 31, 2012 | 09:41 PM
MikeRizz's Avatar
MikeRizz
I tried to take that wire off today after work and the stud broke. It looked clean and corrosion free anyway. So I am buying a new starter.
Is there a preferred one? OEM? Or will AutoZone / Napa, etc.. be acceptable? Which Ford dealer do we get the best discount?
Old Aug 3, 2012 | 08:31 PM
MikeRizz's Avatar
MikeRizz
For the archives, it was indeed a bad starter. I replaced it with a new one and she fired right up. If you end up changing one there are 3 bolts that hold the starter in place, and the top one is not fun to get at!
Old Aug 4, 2012 | 11:39 AM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
Glad you got it going again!!!
I know about the third bolt, it applies to both our trucks apparently. That's why I bought a gear reduction starter with only two bolts on it. MUCH easier to replace...(it's a diesel thing though)
dozerdigger
Aug 3, 2012 10:43 AM
LSJUNIPER
Nov 22, 2010 11:39 AM
dracip
Jan 28, 2008 06:43 PM
orockaway
Aug 28, 2004 10:31 PM
ford390gashog
Feb 14, 2004 11:54 PM
