Upper tie rod problem?
Old 07-30-2012, 01:46 PM
JOHNNYRICH10's Avatar
JOHNNYRICH10
JOHNNYRICH10 is offline
I have some play in my stearing and my truck wanders a little bit. I was thinking it was my steering box. I got under there to look at it to see if anything else looked like it was messed up. Well i am pretty sure i need to do my upper tie rods, i tried to greese them and the greese just oozes out. but i also reached under ther and grabbed the bar. Of course this is with the wheels on the ground. I had no play left to right, but it will twist real easy front to back. Is that normal or could that be the reason for the wondering? 2001 f-250 with 315/75/17 wheels and a 4" lift. 150,000 miles
Old 07-30-2012, 01:58 PM
IowanStraight6's Avatar
IowanStraight6
IowanStraight6 is offline
Jack it up and wiggle the tire left to right up and down and then stick a pry bar under the center of the tire to check for play
Old 07-30-2012, 02:01 PM
lartross's Avatar
lartross
lartross is offline
I don't know, but, I just redid my ball joints and my tie rod ends were "frozen", so I replaced them. I would think, if they move, they might be OK, unless they move too much too easy...It's fairly cheap to do...had my front end alignment checked after aligning with a tape measure and it was exactly right! Guess I was lucky, huh!?
Old 07-30-2012, 02:02 PM
JOHNNYRICH10
I will try and get to that this evening, so is any movement normal, I can grab it and twist it, and it moves alot (twisting)
Old 07-30-2012, 02:04 PM
JOHNNYRICH10
nice, yeah I did my ball joints last year and just opted for the lifetime alignment so im not too worried about spending the money on that. Just want to make sure i know what is right when i decide to change them.
Old 07-30-2012, 07:50 PM
lartross's Avatar
lartross
lartross is offline
Mine are pretty snug.
rakar
03-08-2018 09:27 AM
Pridnjoy
09-29-2015 04:41 PM
countryboy73703
6.4L Power Stroke Diesel
13
09-12-2013 09:31 AM
Jzinkiewicz
05-10-2008 10:55 PM
masseysbronco
1978 - 1996 Big Bronco
06-04-2005 10:09 PM
Quick Reply: Upper tie rod problem?
