Tie rod end replacing
Old May 10, 2008 | 04:05 PM
Jzinkiewicz's Avatar
Jzinkiewicz
My front drivers side tire is showing a lot of wear and cuping on the inside of the tire. Had the upper and lower ball joints replaced. I 'm thinking it's the ball joint on the tire rod. I think i can replace it myself, done it before on my old 250 2wd.
Open to any suggestions.
Old May 10, 2008 | 04:16 PM
big poppa's Avatar
big poppa
Maybe you just need a alignment. Others will chime in that specialize on front ends. Good luck. I'll bump you back up.
Old May 10, 2008 | 04:34 PM
leekingen's Avatar
leekingen
you can the check tie rod end your self. jack up that side until tire off the ground.
grab the top and bottom ant try to wiggle the tire up and down if it moves you may have a bad tie rod. good luck.
Old May 10, 2008 | 04:53 PM
zack7.3's Avatar
zack7.3
I just replaced both inner tie rod ends and it was easy. I just made sure to take some really good measurements of the old ones and when I put it back together it fell right into place. The alignment was still good.
Old May 10, 2008 | 05:13 PM
Jzinkiewicz
How did u know they where bad?
Old May 10, 2008 | 10:55 PM
zack7.3's Avatar
zack7.3
I had my buddy get in there and turn the wheel back and forth while I watched it for play. I did it while the motor was not running that way you can get more of a bind against it. Both of my inner tierod ends had a lot of play. It drives like a different truck now.
Bogeyman66
1997 - 2003 F150
Apr 23, 2013 11:06 PM
JKessler00
Nov 11, 2011 04:49 PM
xxshine
Mar 26, 2011 01:54 AM
sbappleg8
1983 - 2012 Ranger & B-Series
Sep 27, 2010 07:50 PM
guthrie&co
17
Oct 21, 2005 03:21 PM
