Turbo Electrical Connector Help
Old Jul 30, 2012 | 11:10 AM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
Was R&Ring an oil cooler on an '03, and the connector for the VGT actuator on the turbo crumbled when it was removed. Is there a pigtail/ replacement connector I can solder in to replace it? Part numbers from Ford, Napa, whoever would be mucho appreciated, because my only current choice is to haul the whole turbo into the store to figure out what fits.
......there's no way this is some crazy proprietary connector, and that I have to buy a $600 replacement harness because of a 50 cents piece of plastic, right? Looking into Rockauto and Garrett and have found zero info thus far.
Old Jul 30, 2012 | 11:27 AM
texastech_diesel
Token Redneck
Ford VGT Turbo Control Solenoid Pigtail Harness
Is this the right one?
Edit: found a post from bismic over at PSN with the Ford number of 6E7Z-12A690-DA. Apparently I just need to datamine all the forums instead of relying on parts websites
Old Jul 30, 2012 | 06:01 PM
BLADE35's Avatar
BLADE35
Hope it works for ya Bryan
They change part numbers as fast as I can keep up with them
LCA078
Feb 19, 2019 09:26 PM
kmrod
Aug 14, 2013 05:40 AM
JasonWalsh915
Mar 22, 2013 05:47 PM
Sheryle
Nov 18, 2011 01:36 PM
TheDuke
Sep 1, 2007 03:33 PM
