Please ID this part on the turbo pedestal - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
Reload this Page >
Old 02-17-2019, 01:54 PM
LCA078
LCA078 is offline
LCA078 is starting off with a positive reputation.
when I removed the turbo, I broke the electrical connector for what I believe is the ebpv actuator. What part number is that connector thing and where can I get one?
Broke off the electrical connector on this doohickey
Old 02-17-2019, 01:56 PM
LCA078
LCA078 is offline
Also in the mechanics gasket set from diesel O-ring, it has ebpv o-rings. Iím assuming those go to the actuator? I see the thick rings for the oil channels but Iím referrribg to the smaller thin rings.
Old 02-17-2019, 02:10 PM
Walleye Hunter
Walleye Hunter is online now
Walleye Hunter is a splendid one to beholdWalleye Hunter is a splendid one to beholdWalleye Hunter is a splendid one to beholdWalleye Hunter is a splendid one to beholdWalleye Hunter is a splendid one to beholdWalleye Hunter is a splendid one to beholdWalleye Hunter is a splendid one to behold
Ouch! You aren't going to like this. Part # is F81Z-6C673-BA. Here it is on fleabay. EPBV solenoid
And here it is at AutoNation Ford. EPBV solenoid
Old 02-17-2019, 02:29 PM
Walleye Hunter
A good number of guys delete the EBPV and you may be able to find a second hand one cheap here.
Old 02-17-2019, 02:37 PM
AllaboutMPG's Avatar
AllaboutMPG
AllaboutMPG is offline
AllaboutMPG is a splendid one to beholdAllaboutMPG is a splendid one to beholdAllaboutMPG is a splendid one to beholdAllaboutMPG is a splendid one to beholdAllaboutMPG is a splendid one to beholdAllaboutMPG is a splendid one to beholdAllaboutMPG is a splendid one to behold
Or since you live in Tx now might be a good time to do the delete yourself. If you want to keep the EBPV and can't find a free one then you could get something like this and just ask the seller to send you a close up pic of the connector. Swap it out with yours.
I would send you my old one but did just like you and dropped the turbo on the connector. Didn't worry about though cause I had the delete pedestal sitting on the bench waiting to go in.
https://www.ebay.com/itm/1999-5-2003...XdtM:rk:5:pf:0
Old 02-17-2019, 07:55 PM
LCA078
LCA078 is offline
Ouch- that's a stiff price for a little valve! But it sounds like I have a few options:
1) Delete the EBPV but I have no idea if that's a good thing or not? What are the benefits and cons for the EBPV delete? Do I need more parts or just not connect it?
2) Looks like I just broke off the just the plastic part and the pins that actually slide in the connector are still good. I might just push the connector on and wire-tie it in place.
3) Spend 300 bucks... but I don't think this isn't really an option with the other two available.
Old 02-17-2019, 08:28 PM
Walleye Hunter
In cold climates the EBPV closes to help the engine warm up. If you're in TX you wouldn't even miss it.
Old 02-17-2019, 08:32 PM
Skip1970's Avatar
Skip1970
Skip1970 is offline
Skip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputation
u could put a mechanical cable on the ebpv and delete the solinoid.
Old 02-17-2019, 09:26 PM
AllaboutMPG
Like Mark said primary purpose is to help engine warm faster on cold mornings. Some use it as an engine brake when towing by modding the truck or getting a tow tune that does it.
I live in the south like you and only have to deal with so many cold mornings. I wanted to remove obstructions from the exhaust of the turbo for better flow as well as eliminate one of the oil leak possibilities in the valley. There are a few cold mornings that I wish I still had it but that passes in about 10 minutes once the engine warms up
There are write ups on how to remove the valve from the outlet and plug the holes as well as how to gut the pedestal and plug the holes. Another option is to buy a pedestal and turbo outlet that delete them for you.
Here are some links for doing your own or buying.
https://www.ford-trucks.com/forums/8...d-my-ebpv.html
https://www.ford-trucks.com/forums/1...pv-delete.html
https://www.riffraffdiesel.com/garre...h-flow-outlet/
https://www.riffraffdiesel.com/riffr...estal-99-5-03/
Old 02-17-2019, 09:40 PM
DieselDenny
DieselDenny is online now
DieselDenny has a great reputation on FTE.DieselDenny has a great reputation on FTE.DieselDenny has a great reputation on FTE.DieselDenny has a great reputation on FTE.
I'm in the North and I've had mine unplugged for years. It's much cheaper to buy a remote start and just think.
Don't miss it.
Denny
Old 02-18-2019, 09:53 AM
'88 E-350
'88 E-350 is offline
'88 E-350 has a good reputation on FTE.'88 E-350 has a good reputation on FTE.'88 E-350 has a good reputation on FTE.
The pins look ok so you could just put the connector on and secure it with zip ties or maybe a little adhesive. I'd push it on then cover it with silicone, that'll hold it in place and keep water out while still allowing it to be pulled off later if needed.
Old 02-18-2019, 11:02 AM
LCA078
LCA078 is offline
thatís the direction Iím headed right now. I havenít viewed the ebpv delete topics above yet but Iím assuming either way will be fine for a truck with 330k.
Old 02-19-2019, 02:13 PM
Squirrel13
Squirrel13 is offline
Squirrel13 has a good reputation on FTE.Squirrel13 has a good reputation on FTE.Squirrel13 has a good reputation on FTE.
If you want to delete it you need a Non EBPV pedestal, a manual waste gate controller
Old 02-19-2019, 06:59 PM
Skip1970's Avatar
Skip1970
Skip1970 is offline
what is the purpost of manual wastegate controller? seems like you coild over boost and blow heads
Old 02-19-2019, 09:26 PM
Squirrel13
Manual was the wrong choice of words. Non canister solenoid controlled. The spring in conjuction with boost gauge is set to open at a certain osi. The factory setup has a tendancy to be sloppy and open too early
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
