hey yall
i got something i want to run by everyone here. My Daily driver is 01 PSD with just under 300k. when i go to crank after its been sitting half a day or so i get a CES light at start up and it stays on until more or less the engine temp gets up to operating temp. after i reach temp the CES light is gone. i hit the truck with Soulus scanner and found 2 ipr codes ill post them in a bit. im leaning towards a ipr on the way out but doesn't a bad ipr cause rough running and few other noticeable symptoms....truck runs fine other then number 5 injector showing signs of its mileage
any thoughts guys?
Reason: spelling and grammer a product of public schools
Those are ICP codes. Pull the connector on your ICP and see if you have any sign of oil in there. If so, you need to replace it. May not hurt to replace it anyway with those codes.
i just reread my originally post im a idiot my iphone likes to correct what it thinks is wrong it put IPR i intended to spell out ICP my apologizes....
